chaiyuta
very interesting which products will become the first AK4493 DAP. I read many positive reviews from DIY guys~
Thanks mate thats is some exciting news indeedYou still keep your N6? N6 is still an unique DAP consider it runs with dual PCM1792 DAC chips in BTL circuit. i
I have tried the Realizer A16 about a year ago, was completely shocked and I probably will take my card out immediately if the A16 is available immediately. I'll definitely give it a try again when the production version is available.
- N8 will play SACD-ISO, N6 didn't supply DXD, we should be able to add this into N8 support list.
- The tube is completely concealed inside the CNC stainless steel chassis with a small tempered glass window display the LED, we believe it is very safe.
- N8 will have enough power to drive the HD800S to very loud level, it should be reasonably fun but definitely not as good as our desktop gears such as the iDAC-6 and iHA-6.
"N8 will have enough power to drive the HD800S to very loud level,"
Very exciting mate and thank you
Can i please ask a further question then ?
My HD800s have a very expensive , full size balanced XLR (1 left , 1 right) on them
Yes its removable/swappable , but i ve learned the hard way , swapping has caused some damage to another very expensive cable , so i don`t want to do that anymore
So ill ask , is there such thing as a quality adapter to step down to the mini balanced cables you have on N8 , and also to the non balanced output on the N8?
"You still keep your N6?"
i may have to flog my N6 to afford the N8 .That all depends on how much it can bring . i will likely ask that question here later , closer to purchase time
Does the N8 not also run in those dual ?
Thanks mate
Thanks mateYes,
most of the cable manufactures can build extension so that you can connect your cable to the N8 or any other adapter, to have an idea take a look at plussound, in the Interconnect section, you can order the extension(s) you need.
Of course in order to avoid any change in the sound it would be better to build the extension with the same wires you are using for the headphone cable.
Again thanks mateYes,
Again thanks mate
Can you please tell me the exact names/size/types of connections out of the N8 that i would be adapting to my full sized XLRs ?
I hope i explained that correct
If done right , is there a signal loss in this type of thing ?
Cheers
Thanks mateThe N8 has one 4.4mm balance and one 3.5mm SE connector, if it's done in the proper way using quality material there won't be any significace change in the sound and/or signal loss.
I will indeed try to go this weekend, but cannot be 100% as I have family obligations. Is there anywhere in Beijing (like a store) where this demo will stay? Thank youWell, aren't you going to check out the N8 Engineering sample this weekend at Asia Hotel (北京亚洲大酒店)? I am looking forwards to your impression.
Stay updated on Cayin at their sponsor profile on Head-Fi.
Thanks mate
Thanks mateN8 runs on dual AK54497, we can't use PCM1792 in N8 because of the limited digital decoding capability.
I assume you are are referring to something like this:
You need a "Dual XLR female to 4.4 male" adapter in order to use headphone cables like this with the balanced headphone output of N8. For the unbalanced output, you need a "Dual XLR female to 3.5mm male" adapter. These are not commonly available adapters, you probably need to custom make them somehow.
Be reminded that the N8 is designed primarily for portable application, handling high impedance headphone such as HD800 is not a priority requirements, so I won't recommend N8 to HD800 or HD800S users until I get to audition this combination seriously, but getting the right cable for this audition can be tricky,
