I really like the design of the N5ii and the gold volume wheel fit perfectly.There are a lot of suggestion and comment regarding the choice of color and size of knobs. I'll try to response to them together:
(1) The size of knobs are fixed, it is a done deal. We cannot make it smaller because of the mechanical parts inside the knobs. If this is a deal breaker, sorry, I can only thank you for paying attention to our our product and we are looking forward to serve you better next round. We sincerely hope you get the chance of seeing/trying the Cayin N8 one day.
(2) The N8 is not painted in silver, that is the original color of stainless steel. We didn't plan to offer N8 in different color because that will involve covering up the stainless steel surface by paint. We do that quite often if we are using aluminum for DAP chassis, N3 is available in 3 colors, and our other DAPs are available in different shades of gray, but since N8 is in stainless steel, we believe the most appropriate presentation will be brushed or sandblast finishing. It is technically feasible to paint N8 into different colors, if there is an unanimously agreed color for N8, we'll consider that option seriously. So far we have seen a lot of suggestion and opinions, but far from unanimously. By the way, among the several DAP that are available in Stainless Steel, did any of them were painted into different color?
(3) The golden knobs seems to be the focus of the discussion. We have seen different shades of gold in DAP or even IEMs, the Sony NW-WM1Z is basically a golden DAP, the Questyle was available in both gray and gold and I think the golden version is a lot more popular, and the Lotoo Paw Gold also has a golden wheel in the front panel. So the problem is N8 has adopted an "inappropriate" shade of gold? or using the color "inappropriately" in certain location?
In fact, the original design of Cayin N5ii was having a "gold" volume wheel, we received a lot of negative feedback on this issue, so we changed it to silver instead of gold, that was the most popular suggestion at that time, but after we changed the Ni5ii volume to silver, we received over a dozen of request wanting to buy the gold volume version N5ii.
Anyway, to cut the story short (as this is almost 5 am in my side of the world), changing the color of the knobs or the Home button is not complicated, and it probably make more sense then covering the Stainless Steel chassis with blue or black paint. So go ahead and make your suggestion or Photoshop stimulation. If there is an unanimous or clear majority consent on the color of knobs and/or home button, I'll inform our Production Engineer and we shall investigate or try out the suggestion carefully.
On the N8 the gold accents are polished and I personally think they would look ok better against a titanium/charcoal color of the stainless steel body, to add some contrast between the 2.
Another possible solution is to change the finish of the gold elements, from polished to mat so that they don’t stand out too much.
Said that, I’m still looking forward to demo it as soon as available in the US, and if it’s perform very well, I would consider to buy it even if the wheel buttons were pink .
