- Nov 16, 2013
I wish these kind of large transportable DAPs with mediocre battery life would include a feature so that you could listen while plugged in, without risk of damage. Listening will most likely be stationary, and having to stop listening and remember to recharge every 6 hours or so is annoying.
What is the feature within laptops that allows you to work plugged in without long term battery health issues?
Just out of curiosity, when you said large transportable DAP, what is the dimension and weight you have in mind? Does your description remind me of Sony DMP-Z1 ? Hugo + 2Go? Quloos QA390? Shanling M30?
Either referring to removal of battery entirely or battery bypass - which means you can power your device straight out of mains without the internal battery interfering. I think smartphones are starting to get this feature - HS Power Control on the Xperia and whatever Samsung calls it in the S23 Ultra. It could be done in a DAP - would make sense to double up as a desktop (at home listening) and out in the wild (on the go) listening device. Some alternatives if you want to avoid charging every 6 hours - slow charging by using a 5W-8W cable that barely puts enough juice to lengthen the battery (doesn't harm the battery- just slows its discharge), modding the device - voids warranty immediately and is very very risky (physically adding extra battery - some dare to do that, wouldn't advise for it during warranty period as it could brick the device without sufficient knowledge - i.e. voltage, output and technical expertise on how to replace without damaging other parts), another alternative if not streaming is (turn on airplane mode so no wifi/ bluetooth/gps, turn on battery saving mode (slows processor so not running full throttle- shouldn't affect audio but check if you notice an effect), in developer settings restrict background applications to minimum, turn on greyscale/ b&w mode and see what else you can do in settings to extend battery life - if you use a streaming service download to device and then listen). Not the most convenient, but hey these may be some potential alternatives.
If you are willing to go this far to secure an alternative battery option, maybe you should budget 10% of the original DAP cost as the funding to replace the battery after 500 charging cycles. I can't speak for the other brands, but with Cayin, it only takes $30~$40 USD to replace a DAP battery, the logistic cost will cost you more than that but still manageable. Wander how much does it cost to send a DAP from your home place to Zhuhai, China?
Stay updated on Cayin at their sponsor profile on Head-Fi.
