ranjitotski
- Dec 19, 2015
Thanks! Need to check on it!I would recommend the N6ii. I have similar preferences and the N6ii has changed the way I think about portable DAPs.
I would recommend the N6ii. I have similar preferences and the N6ii has changed the way I think about portable DAPs. It's an incredible preformer.
Ask Twister hes the king of flat (reference) sound.Do you think DX220 is more reference sounding and N6ii is more fun? Are they technicaly on the same Level regarding sound?
I think technically these are both top tier DAPs. I don't think the DX220 is more "reference" vs the N6ii. It's definitely cooler sounding than the N6ii. The difference comes in the way these portray the music / sound. I'm switching between these right now and my thoughts are the the N6ii is more dynamic, punchy, and full bodied than the DX220. I'm using the DX220 with AMP8. The DX220 is punchier than the DX200 is (I own the DX200Ti too) so iBasso is headed that way with their kit. The DX220 is a more boring sound than what the N6ii offers.Do you think DX220 is more reference sounding and N6ii is more fun? Are they technicaly on the same Level regarding sound?
Yes you can watch Youtube on it. You should be able to run any of the apps you can run on an Android phone with the same specs.Hello..
I am interested to buy n6ii. But can someone guide me...whether YouTube can be watched on n6ii? Ibasso dx220 has problem for YouTube..
Thanks....for reply.Yes you can watch Youtube on it. You should be able to run any of the apps you can run on an Android phone with the same specs.
This is what I said about the sound quality:Thanks....for reply.
By the way...how is sound quality?
Would it be possible to play YouTube with the screen off? For the music videos and concerts that are on there.Yes you can watch Youtube on it. You should be able to run any of the apps you can run on an Android phone with the same specs.
The YouTube App will do it with YouTube Premium. For free solutions, I did a google search because it doesn't work by default. Just follow this tutorial and you should be good to go.....Would it be possible to play YouTube with the screen off? For the music videos and concerts that are on there.
Odd bug captured in a vid for another item
Every other volume step cuts sound off odd #'s no sound even #'s sound....very weird
Still confused what to buy n6mkii or dx220![]()
The speed, battery life, and not super hot running temperatures are what made me stick with the N6ii over the DX220, but both are amazing DAPs and you’d be happy with either.
That is bizarre, Chris. Could be a defective unit?
Btw, since you guys are talking about volume pot, I have been paying closer attention and noticed that in some cases the volume goes up/down one step with one turn/click, in other cases it takes a few clicks to change the volume by a step. I didn't even notice it before since I usually continuously turn the wheel to change the volume up/down and use touch screen for more precise adjustment.
