Vitaly2017
He can always sell ier-z1r
It might be that E02 just doesn’t have good synergy with your headphone. Same case with my M5, treble is elevated and bass is reduced. However, my other IEMs sound better with E02, it actually tames Z1R’s treble, increases the mids and gives more impact to the bass.
Have you burned it in for a good amount of time? I believe some people here had it running for 200 hours before starting to listen.
I don't think that's about synergy ... I haven't changed my headphones and it sounds better.
Maybe I adapt ... haven't "burned" it 200 hrs or so - I don't believe in burning in, never heard a differences. I believe it's more about adapting to the sound signature than burn-in.
I am curious for how long you been in audio? Why you don't believe in it?
Also the amount of hours you spend per listening session do affect your perception...
Depends on your mood to, state ect
When I first got my N6ii with A01, straight out the box it sounded very neutral and there was no real bass to discern. It was still a good sound but flat across the board. I gave it an hour playing then listened again. I now found little bits had changed. Both listens were not very long. I then left it playing for 50 hours which was the recommendation from fellow head-fiers. I then found it had changed quite a lot. It was smoother and warmer and the bass had really come out. It no longer sounded flat and neutral. To me that was burn in.I don't think that's about synergy ... I haven't changed my headphones and it sounds better.
T01 was the closest in sq to my modified 1z/romi and E02 to stock 1z.
Ier-z1r with stock 1z and stock balanced cable was bright in treble. Like it begged for a pure silver or copper custom cable...
I have not tried ier-z1r with t01 I think its less bright then stock 1z.
I personally prefer Tia Trio an Noir over ier-z1r
wait whaaaaaat!? I literally just put my N6ii back in the mail today for the 1Z to pair with the Z1Rs
To add another data point here related to the Solaris 2020 and hiss.
I use the E01 mostly and the Solaris 2020 definitely hisses. Gain setting makes no difference as I hear it. It's noticeable, but not that bad and inaudible when music is playing except in the quietest of parts.
Tried A01 again briefly. Less hiss than e01, almost completely inaudible, but still there.
Stay updated on Cayin at their sponsor profile on Head-Fi.
A question for y'all.
When my N6ii screen sleeps while playing and then wake up, sometimes it takes two swipes to get to the song list in Cayin player. See the picture below. From left: after pressing volume wheel, after first swipe right, and finally after a swipe from bottom up. Other times, I go from the first screen to the song list.
Is there a setting with Android that's causing this? Can I avoid first or second screen?
Thanks in advance for any tips!
In Android settings, go to Security & Location, Screen Lock, and select "none".
I think in the cayin music app you also have the options with screen lock off or on...
