- May 7, 2017
It booted up again .. but what was this !?
It took a break on you?
I will skip the E01 for that reason. I need 350-400 mW minimum, at least, to drive my IEM efficiently .I am worried about the E01 power output its only 105 mw.
I need 750 mw , but I will try it.I will skip the E01 for that reason. I need 350-400 mW minimum, at least, to drive my IEM efficiently .
S-EM6 V2 primaryLoL what are your iem???
Im using 5,000 MW . Are you happy you sold you Sony iem ?LoL what are your iem???
I never heard of an iem need that much power?
Maybe lcd i4?
My 40ohm z1r out of T01 on 3rd gain and only around 35 volume. And 45 is very loud.
I suspect at 40 ohm its around 400mw I guess. That alot of power man
@jmills8 sorry but 750mw isnt enough, N8 again lol
I hope not .. we have a serious relationshipIt took a break on you?![]()
Nice , I did like the Trio when I had it.Mmm I think I am.
It was good but trio to my ears is more to my type of tuning.
Z1r sounds good but *** that comfort is ridiculously bad.
I tried so much and gave up on it.
Got trio for 2 weeks and already loving it more than z1r! Even baught a plussound cable for them, yep that fast ) one of the most expensive cables I baught so far frankly.
Gold plated silver and a mini interconnect also made with gold plated silver alloy to matches the beauty. 4.4 to 3.5
So now I got that big sound and best cable ) to match it.
Is there a button command to reset the n6ii ? If it’s frozen or something ? Like hold play and power for X seconds ?Pure Class A amplification is fairly uncommon in Personal Audio, we don't have a lot of reference or reviews that cover this topic very well, but in speaker application, 10W Pure Class A is very different from 10W Class AB. A 50W Pure Class A amplifier will easily outperformed a 100W Class AB amplifier when come to driving capability. So let's wait for the impression from users and Reviewers, I am sure someone will compare the T01 and E01 side by side with demainding headphones.
With our current product roadmap, we don't have any plan to make "longer" Audio Motherboard, there are enough options on our waiting list to keep us busy for quite a while already, and these are all within the current physical dimension of Audio Motherboard chassis.
