seanwee
- Jun 9, 2015
No luck unfortunately :/good luck with the
Dx220.
At 126*70.5*18.7 and 240g it's not much smaller than the DX200 so it's still bulky
Dx220.
FiioNo luck unfortunately :/
Perhaps when they release the M13Fiio
DX200 with amp 8 (4.4mm balanced module) does 6.2 vrms for comparison.
Thats 6.2 x 6.2/32 = 1.2 Watts /1200mW @ 32Ω
A little overkill if you ask me
I would prefer longer battery life but some may want more power.
Stay updated on Cayin at their sponsor profile on Head-Fi.
You walk a lot ?Perhaps when they release the M13
The M11 probably wouldn't be a big enough jump from the N5ii to be worth it.
Do you think Iconic will stock it for a demo when its available?
Yes, which is why Im looking for more portable options.You walk a lot ?
Im in Hong Kong. Im doing a 3 hour commute with the N8 since November 2018.Yes, which is why Im looking for more portable options.
The most frequently asked question about N6ii so far :
The Suggested Retail Price of N6ii (with A01 Audio Motherboard bundled) is US$1,199
When and where can we buy it?The most frequently asked question about N6ii so far :
The specification are as follows:
I'll rewrite the Post #1 later today, if you have following all the updates recently, there isn't anything new, but I'll do that to make it easier for new comers.
While it may be OK for you its a bit unwieldy for me. Your mileage may vary for these kinds of thingsIm in Hong Kong. Im doing a 3 hour commute with the N8 since November 2018.
Pls tell me you guys will do an Audio Motherboard with multibit (or R2R) DAC chips?
