Short update on my story : i could partially fix the issue. By going into apk system services through ES Explorer, i could finally disable the Google Services Framework. This, at least, let me listen back to my music ! But it's still far from being completely solved as for some reason, i cannot access or download my apps through the Play Store. Sometimes the Play Store will just crash and sometimes it will keep saying 'Checking info' forever, So i never access the app library and i cannot get my apps back :/ And if i re-enable the Services Framework, then the msg error keeps again being displayed every second or so.
Note that i already tried clearing Cache and/or Data of all Google Services with no go. And neither Factory reset nor different firmware version could help so far.
I think i will try returning it for repair to my seller as it really seems there's a major issue with my device.
I want to add that i'm rather disappointed with Cayin support. The better fix i could find was just by myself. No reply at all from them in here. And through their mail support, i only had a suggestion of downgrading firmware which didn't help. I told them the issue was still here after downgrading firmware (5 days ago) and even sent them my video link above clearly showing the issue, but they didn't reply since Not only for suggesting me to disable the Framework services (which indeed partially solved the issue), but not even for just saying to send the unit back for repair ! Maybe they're still trying to investigate my issue on their end but i definitely highly doubt about it... I also sent a PM to Andykong in this forum a few days ago, but still with no reply at all so far.
Anyway, not a that-much efficient customer service if you're asking me...
@Andykong @CayinSupport
