Cayin N5ii Android based Master Quality Digital Audio Player
Discussion in 'Portable Source Gear' started by PinkyPowers, Oct 14, 2017.
256 257 258 259 260 261 262 263 264 265
  1. shahkhan
    How is the power of N5ii balanced compared to Dx160? Is there huge difference?
  2. seanwee
    Its about twice as powerful.
  3. shahkhan
    How is sundara scale up with N5ii? I'm have Hd58x, but want some neutral can. Looking towards sundara, hd600, dt1990 as options. But having the fact tht n5ii and sundara both neutral, I'm afraid the overall signature may be too bright.
  4. seanwee
    Depends on how sensitive you are to brightness. The Sundara is neutral bright, HD600 is warm and the DT1990 is just straight up bright.
    I find the N5ii + Sundara pairing to be quite good. The N5ii is neutral warm so I guess it complements the Sundara.
    MyPants likes this.
  5. Sephion
    Both the 3.5 and 2.5 outputs are not working properly on my device (just hear from one, need to adjust the jack constantly)
    Is there away I could send it for reparation in Europe? And how much would it be?
    Thanks in advance
    GilZ likes this.
  6. originalsnuffy
    So near yet so far to get Amazon HD going (continued).
    I have sideloaded the latest APK for Amazon HD.
    The app starts; I can pick songs, get the graphics, but can't play anything. I can even scroll lyrics!
    For online playback, the wheel just spins.
    Can't download; the settings menu says "your SD card is offline".
    The app knows who I am; it can see my playlists; artist, songs, etc.
    Feels like there must be some kind of workaround as the app is getting so darned close to working.
  7. Andykong
    For hardware repair after warranty service, please contact service@cayin.cn, they might be able to coordinate some help in Europe locally.
    Cayin Stay updated on Cayin at their sponsor page on Head-Fi.
    http://en.cayin.cn/
    Sephion likes this.
  8. GilZ
    I am also facing the same issu with 2,5mm balanced output.
    I have to press on LO/PO button each time to activate 3,5mm output.
    Doesn't seem so complicated to repair, would be great to have the reference number of those outputs and some sketches or pictures to help repairers.
    Is there a recommended repair shop in Europe (Germany) ?
  9. Infoseeker
    Wrong topic
  10. Nawin Sapchinda
    Hi
    Did anyone have this issue
    I try to use N5IIS as Usb dac with my PC
    But look like It now working properly
    Like when I watch YouTube and Netflix.
    Its sound delay for 1 sec from video
    Its Normal?
    I use ak dap before its work perfectly no delay.
  11. originalsnuffy
    I was really hoping there would be some way to run the Amazon HD app (sideloaded) on the N5II. I run in to a similar issue that came from a FIIO unit thread. I just get to a point where the wheel spins. Has anybody been able to get this app to work on the Cayin N5II, and would this workaround give a hint as to what is needed to get things to work?
  12. originalsnuffy
    OK I realize very few people are frequenting this thread. But for those who are, I was wondering if Tidal was ever made to work with external SD cards for downloads or if the unit remains limited to the internal memory. Tidal is running a cheap trial and I thought it might be fun to fiddle with it. I never could get the Amazon HD app to run on the unit so Tidal is probably the best bet. Thanks for the info.
  13. shahkhan
    Hi, which browser you people use? Suggest any fast browser, suitable for slow 5.1 Android in N5ii.
  14. originalsnuffy
    Just as a follow up. For $2.00 I couldn't resist doing a Tidal trial. I listened to a redbook of Procol Harum Live with the Edmonton Symphony Orchestra and it sounded very good. But I will be limited to about 25gb of downloads so I am unlikely to renew the trial.
    I am pretty enthusiastic about Amazon HD but it appears that it is unlikely to ever run on this unit. Such a shame.
