Reverber
- Sep 7, 2016
I have no idea why someone bothered by so-called '2 sec delay bug'
Iam for proper USB Audio
Come to think of it, the firmware only seems to fix the 2 sec delay so those who'd prefer having the USB Audio out could just defer from upgrading.I would suggest that you offer the firmware update with the information that certain capabilities have been removed or degraded. Those who want those capabilities as they are can stay with the current firmware; those who would prefer a more responsive interface can go to the new firmware.
As I understand it, the primary USB issue is output to external DAC units such as the Mojo. I am not sure if there is an issue with use as a DAC/AMP as I've never tried that function. But it would be good to know the current status of those two USB uses and what would happen with the proposed new firmware.
Personally a snappier UI would be great for me as it would address one key issue for me. The other key issue for me is that sending files via USB to the micro SD cards can be finicky; but I suspect that USB transfers may never be fully addressed due to the limitations of the USB implementation as described a while back.
I've heard the op amp circuit of the N8 and while it's not comparable to the nutube circuit it'll definitely be a great one at the 1200 buck price range.As a N5II user, don't think worth compensate one function, even though rarely use and can't output smooth DSD
also possible lower SQ for the 2sec issue .. as above user said, a bit annoying but it's ok.
I thought 2sec issue occur only on 3.6 FW ? or since 3.5 ? but sure it was not on 3.3 ..
so vote for unchange
didn't notice the developer option, thx @seanwee, feel flashy after setting your options
let's bring it out for listen tmr
for the N6II, shouldn't be a secret as posted by Andy, it SRP is 6998RMB, so comparable to DX220, both are in range : P
can't wait to listen both !!
All of a sudden my n5ii won’t scan past 600 songs
I second the idea to better the USB capabilities would be a better use of firmware update. What is the 2 second issue?
@Andykong any update on the startup volume issue where the device doesn't startup at the preset volume, it plays at the previously used volume? I still feel like this is a big issue for damaging ears/headphones between uses.
