seanwee
- Jun 9, 2015
Isn't amp 8 better?Make sure to get AMP7 with DX220, that's a really really interesting experience.
I'm curious to compare it to N6ii (?)
Isn't amp 8 better?
Has anybody tried 3rd party music apps such as Neutron on this device? Any better then the stock player?
Any recommendations?
Thanks
Stay updated on Cayin at their sponsor profile on Head-Fi.
I had similar problems with Outlook. It just kept choking on one email but boy it was hard to figure which one that was.....basically had to cut the email stack in two, see which half froze, then cut that half again....etc.
Currently I'm considering the DX220 since the price of the N6ii is a little too steep. The FiiO M11 on the other hand may be too small a step up to be worth it.
Considering it but probably won't get another amp module anytime soon due to budget constraints.The DX220 is a very good upgrade for N5ii, you get must faster CPU and a high quality screen to start with, almost certain that it will improve your user experience instantly.
I auggest you give yourself a treat and go for the Amp7 or Am8, or both, depends whether your IEM collection is single ended or balanced, or whether you need Line out. Trust me, if you go for Amp3 or Amp5, you will be tempted to move up to Amp7 or Amp8 very soon, you can mark my word for that.
USB Audio output or USB DAC mode?One simple question that I need inputs from N5ii/N5iiS users.
After a lot of attemp, we can solve the 2sec delay, finally. The solution involve a lot of low level programming and the worst part is, the new code will deteriate the USB Audio and created high background noise. I understand the current USB Audio is not good beyond 16Bit/48kHz, but this new beta firmware will make the USB Audio even unusable at all sampling rate.
If we go for this solution and pack it into a new firmware, we'll either disable the USB Audio completely, or pop up a warning on the noise problem of USB Audio. Yes, this is not ideal in both case, but we honestly cantc find a way to solve the 2sec delay bug and keep the USB Audio intact simultaneously.
We are sourcing opinion from our dealers right now, if you have a preference, you can tell me here or by PM. I am heading to Munich today, will check again when I settle down at my Munich hotel.
USB audio out is useless to me anyways. Its unusable. I’m ok with having it disabled.USB Audio output or USB DAC mode?
If its USB audio output then its fine for me.
I am fine with no USB Audio Out as I dont use that featureOne simple question that I need inputs from N5ii/N5iiS users.
