jmills8
Previously known as bmiamihk, jmills2
Guess we have different iems.Cayin N5, Shanling M5, Soundaware Esther Analog, and LPG FTW!
No amps needed for my IEM, either
yep had that one. My iems never hiss if they did Ill throw it awayOr different taste, different tolerances, different requirements. Personally, I'd rather not stack unless absolutely necessary for power requirements. Not needed for the IEM I'm using. If I were using an amp, it'd be my ALO Rx to control hiss and / or provide greater fine volume control as needed.
Have received my 75 Ohm impedance adapter which I ordered to eliminate the hissing of the i5.
And the impedance adpater does exactly that. After plugging in the adapter I had to adjust the Volume from 23 to 38-40 in low gain.
However, it will make the base sounding somehow thinner and voices
will become slightly tinny. Maybe it could even be compensated with EQ, but I did not have the time to try that out.
So I rather go for the slight hiss which anyhow is tolerable. Next IEMs will be less sensitive, so that should solve it.
But for 8 Dollars the adapter does a decent job I must say. Build quality is very solid and the effect on SQ is less significant
than what I expected.
I agree with this "Cayin N6 N6 features more rich sound, with some hint of softness, giving more "musicality" to records, so generally, N6 sounds a step higher."Here is my humble review of I5 http://www.head-fi.org/products/cayin-i5/reviews/16739
Due to some error it's not showing in review list on Head-Fi's bottom (at least for me)
This surprises be, as I've heard almost all of the Cayin portable lineup released to date with the exception of i5, and I've found bass better for my tastes from C5 / N5. In fact, I really prefer N5 over N6 and fully expect to prefer i5 over N6, as well.
Guess using a bass iem helps. N6 much cleaner than the n5. Usued Aurisonics 2.5 iem and the JVC SZ2000 HP. Plus I amp the n6.
Stay updated on Cayin at their sponsor profile on Head-Fi.
It is getting a bit quiet here....Is that a good sign or a bad sign?
Hope that means they are busy fixing gapless, the 30:00 bug and album artist sorting for the next firmware.....
The bass from N5 offers very good music foundations, it brings out the ambiance and atmosphere, if I have to pick a headphone to describe this feeling, it is like the LCD2.
N6 offers better resolution and linearity in its bass department, if I have to pick a headphone to describe this feeling, it is like the Beyer T1.
So it really depends on what you are looking for and what type of music you are listening to. I actually prefer the bass of N6 if I have to take a side
Well, I can give you a date to look forward to : 7 September 2016.
Unfortunately .....
By the way, you have tested the i5 with ZMF Omni? Can i5 handle this planar headphone satisfactory? They are pretty demanding for a portable device, I probably will use i5+C5 combo instead. I have the Alpha Dog which is also a T50RP modded headphone, the i5 can drive it very loud, but the soundstage is narrow when compare to the iDAC-6/iHA-6 combo.
n5 + c5 andy
