Yura Buhanovsky
- Aug 10, 2016
I told Andykong in the case of critical errors in the firmware desired option return to the previous firmware version . In the factory no function recovery backup (nandroid) , then we need to allow the user to return to a working version of the firmware . And what happens , Cayin has released raw firmware with errors and the users do not have the ability set back , and sit outside with your bricks . So I ask why buy this raw product ? Guarantee from getting root ? My tablet has Nvidia 6 firmware versions , and I can at any time change without any restrictions , to choose the piercing that I like . And Nvidia won't make my warranty because of this . I wanted to buy i5 but now I have serious doubts to buy . You need to remove the limit , delete check the date of build !!!!!
Code:
[color=rgb(33, 33, 33)] I judged the firmware and see that there is check the firmware date. If you remove this line, you can flash the firmware and the old. And since the installation process completely, and firmware update is digitally signed, it is absolutely safe. And I do not understand why there is no desire to realize it. No one can do the same root or to put custom firmware.[/color]
