- Oct 10, 2002
Gents, editing out this post because MOTs have be neutral in what they say in this part of the forums.
Maybe something to consider, the Woo WA22/WA6SE has NP with the HD-800's, but those Woos simply fall flat when using a pair of HE-6's. On the other hand the LF so far seems to handle the HE-6's very well.
Once I get over the 150 hour mark on my LF I will give my HD-800 its day in court with my LF/DAC1+caps combo + using the rest of my system.
I have an OPPO BDP-95. The combination of the 95/LF/LCD2 is pretty impressive.
And gents, in case some are not aware, the second production run pre-order is now open. Delivery is expected in October. See the website.
Yes the BDP-95 with its ES9018 DACs is very impressive for analog and that is the reason why I got the W4S DAC 1+caps (ES9018).
Up until my Realiser offered a upgrade of HDMI in/outs I really liked the analog audio of the BDP-95. However I now use the HDMI port 2 of the BDP-95 for MC LPCM connected to my Realiser , so there is no need now to use the analog ports of my BDP-95.
My chain is BDP-95 via HDMI----->Realiser HDMI in, Toslink out---->W4S DAC1 out via interconnects---->LF---->HE-6.
Wow, it seems like you could downgrade to a BDP-85 at this point and not notice a difference if you are outputting via HDMI.
Yes I could down grade to a BDP-93 with NP, and not that the BDP-85 would not do the job as far as AQ via HDMI but its lacking in some other features like one HDMI port for just video and one HDMI port for LPCM up to 7.1 audio out to my Realiser.
SS, I'd really really really like to know if there is a difference using the BDP-95 as a standalone or how it compares in combination with W4S. Since they both use the same DAC, does the W4S add anything (this would only apply to CD's). Thanks.
Yes that is something I want to know also. Right now I only have about 60+ hours on both my W4S Dac and LF amp, plus I had W4S use (upgrade) the same caps that are used in there DAC2, so I would end up with the same AQ in my Dac1 as is the Dac2.
So I hope by next weekend to start my comparisons.
Someone asked about comparisons between the LF and Red Wine. Here is one post from headfi.
http://www.head-fi.org/forum/thread/512917/where-can-i-do-a-pre-order-for-the-cavalli-liquid-fire-or-liquid-gold/30#post_7427396
Also, there is an expanded post from avguide by the same gentleman.
http://www.avguide.com/blog/first-listen-cavalli-audio-liquid-fire-hybrid-headphone-amplifier#comment-51831
Scroll down to the comment section. Hope you find this helpful.
