Really?
That cheap? Black or brown cable?
Yup I used a similar cable with my Solaris and my Anole VX and both were great.
Really?
Similar is not the same brother.
Which of the two in the link you've sent me though?
There's a black one and a brown one.
It's cheap so no problem to get to test but i don't suppose it's gonna be better than the stock one, is it?
Also was looking for a used cable around $200-$250
Will search to find spiral dots on amazon.co.uk hopefully.
Still trying to find a good cable with 2.5 balanced termination.
I strongly recommend the Symbio W Peel if you're having trouble finding a quality tip for Solaris.
I have a set of medium size Symbio wide bore orange with the foam and they will not compress to ender my ear canal deep. Maybe i need a smaller size but they are good for other IEMs that have a shorter stem.
Ah nice!That's why the Peels are awesome. They remove most of the hard foam and leave only the foam core and the soft outer shell. Good value for the price in my experience.
Ah nice!
Will look for a set then.
I got the ones I currently have with an IEM from another member.
Can you share a link from where I can acquire them?
Looks good too!Dunu Blanche just came in. Testing with 2.5 and amp1ii today, 4.4 and amp8ex tomorrow. Sounds great so far.
Looks good too!
Price?
$329?
