- Jun 22, 2015
I have the ADV Eartune Fidelity tips. My Solaris OG was used for the master for these tips. The current version with the large bore hole works great with all three Solaris models, OG, SE and 2020.Thought of custom tips?
They are extremely comfortable and improve the sound significantly over any of the tips I tried. I also like how you can keep the custom tip in your ear and only remove the Solaris when you need it to talk to someone.
It does take a little time to get used to how to insert them. What I find works best is insert the tip and make sure it's fully seated, specially the top part of the tip that fits between the Crus of helix and Inferior crus of antihelix (this picture shows what I'm talking about, https://www.researchgate.net/figure...-Antihelix-3a-Superior-crus-of_fig1_332735738). Then insert the Solaris.
The only downside to these tips is with the OG and SE because they are so large they will stick out a bit more than with the normal tips. The Solaris 2020 doesn't stick out as much.
