Campfire - Solaris
post-15000944
Post #5,386 of 9,485
MaxD
post-15000947
Post #5,387 of 9,485
MaxD
OK as promised my initial impressions:
Using both the DX220 and the Mojo/poly to test
Picture from left to Right
Original stock cable.
Lovely balanced sound, I listen to vocals a lot so I tweaked the 2-4k region ip by maybe 2.5 Db. Now the stock cable sounds perfect. It all sounds like live music across the spectrum. Imaging is good but a little condensed for me.
My custom pure silver Litz cable.
The 2-4k tweak no longer needed. Is it because its silver or because it is balanced ? A tiny bit more detail.
The new CA cable Pure Silver Litz 2.5 balanced.
No tweaking here. Sounds the same as my home made cable. Maybe a little more detail and image. But, the wire is more flexible and I was surprised to fine thinner and more flexible than the stock. Also no ear hook memory wier like the stock.
This is now my new permanent cable, worth what it cost.
post-15002084
Post #5,389 of 9,485
fokta
Jakarta
Jakarta
Now I know my ear canal better, my left ear canal bore is bigger than my right.
so need to use large on left side. but if I force large eartip in the right, I experiencing Flex, but the isolation is very good.
so I used different size eartip, Large on the left, and Medium on the right...
Reactions: ExpatinJapan
post-15002097
Post #5,390 of 9,485
cycheang
Malaysia
Malaysia
congratulation, you found the best match. May I know how much you bought for the
CA cable Pure Silver Litz 2.5 balanced ?
post-15002151
Post #5,391 of 9,485
MaxD
I bought it in the UK which is always a bit over inflated. It cost £199.
Reactions: 435279
post-15004207
Post #5,392 of 9,485
Peter68
New York
New York
Age
51
Hey Peter,
I have not, will do and report back.
Cheers
Ken
@KB, were you ever able to find some time to use the KANN Cube with the Andromedas? I'm almost ready to pull the trigger on a Cube purchase but would love some info about how it matches up with the Andromeda first. Thanks very much,
post-15004259
Post #5,393 of 9,485
cr3ativ3
Germany
Germany
I’m on board :)
post-15004271
Post #5,394 of 9,485
cr3ativ3
Germany
Germany
Initial impression is that the band is sitting in my room next to me with this combination
Reactions: fokta
post-15004417
Post #5,395 of 9,485
fokta
Jakarta
Jakarta
post-15004430
Post #5,396 of 9,485
cr3ativ3
Germany
Germany
post-15004485
Post #5,398 of 9,485
cr3ativ3
Germany
Germany
post-15004659
Post #5,399 of 9,485
cr3ativ3
Germany
Germany
Can you please let me know your impression withe the fiio LC and solaris .
It’s the Fiio lc2.5c i will check out tomorrow und reply to you here
Users Who Are Viewing This Thread (Users: 9, Guests: 11)
