Just got back from the Fujia-avic spring headphone festival show. See some pics at the end of my post. Great show!
https://www.fujiya-avic.jp/user_data/headphone_fes.php#
I just want to make people aware of how a custom slip over can change the over all sound of your IEM. A custom slip over for your universal IEM is a great idea, for comfort and better isolation. However I would like to caution everyone who has these that if they are not optimized for the shortest bore possible it will adversely affect the sound of your universal. I have been working on this here in the Campfire Lab and found that its a can be a nasty outcome. I addition I have seen some Solaris custom slip overs that I feel could have been made better - shorter sound bore-. The universal IEM slip over part needs to be modeled such that the IEM is positioned as far into the custom slip over as physically possible. If the universal IEM is pulled back the sound bore of the custom slip over will add length to the sound bore and your whole freq will be rolled off. See demonstration doc on a typical BA and the affect of a longer bore.
Disregard the black (no tube)
focus on the peaks at 5000 - 7000
the longer the tube = more roll off / pushed back
Ideally the slip over would not add any length to the sound bore into your ear or be minimal.
These are some I saw at the show last week and appeared to be a good build. I am not sure who all is making custom slip overs but just wanted to caution on this. Fit is so critical with the Solaris, I have seen people report definitive renderings that I think are not representational of the IEM due to inadequate tip fitting. If the sound bore is too long or your foam tip or silicone tip is not fitting well its not the Solaris's fault. I have never encountered a IEM where the fit has such a critical impact on the overall sound. Generally a deeper insertion on the Solaris is going to yield the best sound. I hope this helps.
Show pics.
Thank you,
KB
Great stuff, Ken! Congrats on all your new launches.
