syke
- Mar 1, 2009
Campfire and others do make custom tips...
I do have custom tips for the Andromeda. They will never sound like CIEMs. It will always be a compromise.
I think Andromeda is at top custom level SQ with the right set of tips. Only advantage I can think of with custom is extreme sound isolation (high noise reduction), which increases clarity.I do have custom tips for the Andromeda. They will never sound like CIEMs. It will always be a compromise.
Perhaps canals on the narrower side? I wear large tips usually so only have issues when tips arn't large enough. Symbio Manderin W, wide bore works well for me.I am really after comfort to be honest. Wide bores like the Andromeda don't really work well with my ears.
Can you post a pic of your custom tips?My ear canals are not only narrower, they are in a weird angle as well.
here are mine:
Looks comfortablehere are mine:
Looks comfortable
Where you order this ?
I had asked and ken and had said they were still in developmentsend CA an email and they will sort you out. you will need to send them impressions.
Look for a source with between 1 to 2 ohm output impedance. Lower or higher changes the freq response. Or grab an IEMatch to get to that impedance sweetspot. Opinions are mixed on its impact on the sound.Just picked up the Andro S and I've been skimming through threads looking for the solution to a source w/o hiss. I'm currently running them through my Fulla 2. The hiss isn't terrible, but I wouldn't mind it being gone. I was looking into the Mojo, iFi, or maybe a magni3/modi mb options, but it seems like everything will have hiss. Does anyone run a source that has no hiss with their Andros? This is for a work area, so I can't have a huge setup; hence, why I have a fulla 2.
Do you also have the iFi Purifier3 + Galvanic3?Look for a source with between 1 to 2 ohm output impedance. Lower or higher changes the freq response. Or grab an IEMatch to get to that impedance sweetspot. Opinions are mixed on its impact on the sound.
I love mine with the iDSD Micro BL. Much prefer that to the Mojo. But the Micro may be overkill.
Lots of recommendations on this thread. Happy reading!
