Campfire Audio - Introducing 2 new models Hello Andromeda and Nova
Apr 4, 2017 at 4:28 PM Post #3,916 of 9,829
I'm quite happy with the iPhone 6 & Andromeda. If it sounds good I'm down with it, doesn't need audiophile credentials to sound good.
Apr 4, 2017 at 4:49 PM Post #3,918 of 9,829
just the iPhone with no additional amplification?!
Doesn't need it. Plenty of volume for me even at 50% of iphones volume output. They are very sensitive so they don't need much juice.
Don't overlook the iPhone guys. iPhone with TIDAL and the Andromeda is simple bliss.
Apr 4, 2017 at 7:47 PM Post #3,919 of 9,829
Currently I am using DFR for amp but it is only good when connecting with laptop not iphone :(
and I did order Spiral dot tips but dont think it will improve much for bass
- I know cable can change SS with a decent impact but is that wm1a could provide a significant impact on Bass.
thanks
Apr 4, 2017 at 8:09 PM Post #3,920 of 9,829
The iphones I've tried have resulted in a mostly neutral sound signature so it could be that you need a different source for more bass. The Andromeda sound varies depending on source more than other earphones I've heard. That being said the biggest factor for bass would be the tips. Anything after that will have a smaller impact.
Apr 4, 2017 at 8:51 PM Post #3,921 of 9,829
Out of date but still a good reference for output impedance (which matters where bass and retaining intended signature is concerned for BAs)
http://monoadc.blog64.fc2.com/blog-entry-99.html
This blog puts the iphone 6 at around 3.2ohms.
http://archimago.blogspot.jp/2014/10/measurements-apple-iphone-4-iphone-6.html?m=1
I dont know about the 6S
1 or under is ideal for BAs
Imho
Apr 9, 2017 at 7:25 AM Post #3,922 of 9,829
I just got my Andromedas just now. I currently have problems getting a good fit with the included tips. I have read that the fit on the andromedas are tip dependant. I find that they don't insert deep enough. Are there any recommendations? Thanks
Apr 9, 2017 at 8:48 AM Post #3,925 of 9,829
Have you tried the small stock foams? I find they give off the best frequency response.
I have tried them but there was still a problem with the fit. I think the problem is that they don't insert deep enough.
the spinfits fit the best for me.
Spinfits always work for me especially on the Se846 but they didn't in this case :(
Apr 9, 2017 at 9:04 AM Post #3,926 of 9,829
Try JVC Spiral dots tips. They hold better than default.
Or you can get Symbio tips from ebay.
Apr 10, 2017 at 12:47 AM Post #3,928 of 9,829
I had to go with bi-flange tips on my Novas. They are the only thing I use a bi-flange on.
I usually use Spiral Dots, but they wouldn't work well on the Novas for me.
Apr 12, 2017 at 11:27 PM Post #3,929 of 9,829
The OI of the iP7 lightning to 3.5mm will handle the bass for you. I still prefer the DFR for iPhone duty but hat the bulk. It brings a little more realism into live performances to me but you definitely don't need the power. I'm curious about the new lightning cabl they have for he andromeda but I wished it had a control knob and mic.
Apr 12, 2017 at 11:52 PM Post #3,930 of 9,829
How does the lightning port work anyway? Is the signal digitally transferred into the cable termination and processed again via a separate DAC in the cable termination itself or is it transferred just like any other analogue jacks, yet with different port size?
If the signal is digitally transferred through the jack, a separate DAC in the litz cable must affect the sound quality somehow...
