Campfire Audio - Introducing 2 new models Hello Andromeda and Nova
Feb 21, 2017 at 3:04 PM Post #3,782 of 9,829
I don't want to say which one is better,I can tell just different
U12 very smooth and relax. Andromeda more sparkel and very nice sound .
I love both but Andromeda Closer to my taste.
Feb 22, 2017 at 12:17 AM Post #3,783 of 9,829
I don't know which tips I should use :(
I keep going back and fourth to my spiral and the foam tips that comes with the andro (not the comply one)
Feb 22, 2017 at 12:33 AM Post #3,784 of 9,829
You should try this
https://www.ortofon.com/silicone-eartips-set-p-577
Feb 22, 2017 at 3:44 AM Post #3,785 of 9,829
Well, comfort first, followed by sound. Have you done some A/B comparisons with the same tracks?
I don't like silicone with the Andros. That includes the simple tips that come with it, the SpinFits and also the SpiralDot. They make it sound a bit thin to my years, too bright.
The included foam is OK, but not particularly comfortable. Comply TX-400 got me the best comfort and probably with the best sound. Plus, nozzle protection mesh.
Liked them so much I ordered a second pack with a S+M+L size mix. Initially I got the Mediums, but for some reason the left ear canal seems to prefer smaller tips.
Feb 24, 2017 at 4:21 AM Post #3,788 of 9,829
@beowulf is the ifi hiss free with your andros?
thanks in advance
Yes, totally hiss-free. Even with IEMatch off (although I use it in Ultra Sensitive).
Besides my desktop gear at home, it's the only amp/DAC combo I tried where the Andromeda hasn't picked up at least a little bit of hiss.
The ifi BL has has a pretty clean circuit design, it seems.
Feb 25, 2017 at 5:23 PM Post #3,790 of 9,829
Cable testing and reviewing has now begun. First are the ALO Audio Tinsel, Litz and Reference 8 cables.
Whoa--what is that box in the middle that you're using?  Looks like an ideal way to A/B/C things!
Feb 25, 2017 at 9:20 PM Post #3,794 of 9,829
I'm not a believer in significant cable relevance other than in ergonomics, to say the least, but curious to read that and see how the green monsters perform.
