Campfire Audio - Introducing 2 new models Hello Andromeda and Nova
- Thread starter KB
If I move the connector on the cable Left and right it kinda feels loose, is this normal?
blazinblazin
- Nov 19, 2015
You mean it spins around?
No if I just move the connector left and right, up and down or side to side it kinda feels loose and sometimes it makes a clicking noise.
I have the stock cable
blazinblazin
- Nov 19, 2015
My stock cable only spins around cant move like a joystick.
It's a tight fit.
It's a tight fit.
It's a tight fit.
some reason mine feels loose and makes some clicking noise when I move it. You know where the thing that connects to the iem
Maybe it's nothing and I am worrying to much.
EDIT: JD from support told me it is normal and there are some tolerance in movement.
blazinblazin
- Nov 19, 2015
It won't drop out, it will just spin.
Too secure, very hard to remove cable too, but i found a weaker point that is more easier to plug the cable out when spinning the cable around.
cocolinho
This probably happens with many other IEMs, but that fat Mickey Mouse nozzle on the Andromeda just makes it more visible,especially not being a mesh. The very open tips might make this look more obvious but probably also make the condensation evaporate a lot faster when the IEMs are removed...
Here's my nozzle before and after a minute. The condensation moisture fully evaporated...
I'm going back to this. I'm worried about this and it happens quite quickly on my pair of Andromeda freshly arrived.
I asked Ken if there is any risk to deteriorate IEMs, I'll keep you posted.
willowbrook
- Oct 25, 2012
As long as you keep them dry afterwards and be careful when wiping the moisture off, it shouldn't have any ill effect.
blazinblazin
- Nov 19, 2015
After wearing wipe dry. That's what i do.
Nozzle face down after use, dont lei any droplets or dust have any chance to drop inside. (Usually won't drop in, so far when i am using)
Is there a way to tell if it is a real Andromeda? I am looking to purchase an Andromeda in nickel, but it is very difficult to see if it is the Andromeda in nickel or a set of Novas.
Midgetguy
You sure it was a silver Andromeda? I thought they only came in green. In fact, I thought the entire lineup only came in 1 color for each IEM. Never heard otherwise.
I have seen a couple for sale on the classifieds and no ones flagged them or anything so I hope they are a real thing haha. I really would love a set of andromedas but the green is such a turn off for me for a flagship product.
- Sep 27, 2016
The green color is really beautiful in person. The color seems to change depending on how the light hits it. And of course the sound is incredible!
Is the green kind of iridescent then? it looks the same in all the pictures ive seen. If it subtly changes colors depending on how you look at it i may be interested in the regular color too haha
Total: 9 (members: 0, guests: 9)
