RexAeterna
- Jul 22, 2010
i know it's meant to be mandatory for some but i haven't had any issues with either my amps or tried recapping them. only way to test the caps is take them out and i kinda don't want to mess with it unless i was actually considering doing a recap job. i will consider recapping in the near future but for now i'm gonna take care of the smaller things and do bias adjustment and so forth. only thing i be recapping soon is some crossovers for my pioneer cs-77a speakers i found since the caps are way over 30 years old and past their time and the fb drivers used are really good drivers especially the woofers. i might even build a new wood cab for my 5000x and paint it black. i'm a sucker for wood cabs on receivers.
The general consensus on AudioKarma seems to be that outside of the main filter/reservoir caps (assuming those are OK), recaps are mandatory on older gear - out of spec caps will color the sound as much or more than new replacements would change it from what it was. What is considered generally sacrosanct are the output devices. If you change those, why bother buying the vintage piece other than the looks. That makes sense to me, so that is the path I have followed. Old caps can also pose somewhat of a hazard, too, so best to recap as needed. And of course re-aligning the tuner is not replacing any vintage parts...
