Rawrbington
- May 12, 2011
i don't know much about either one, but i have heard some of the old Kenny's and they are all very good. and at 50 bucks you really can't go wrong if it works.
Any thoughts/opinions on a Kenwood KR-6060 for ~$50 or a Sony STR-7065 for $140?
Are these units well regarded and prices reasonable. Not much here on Headfi, but the Sony seems well thought of and both prices seem pretty reasonable to me.
Thanks.
Both great units. The Sony was TOTL for it's model line and is build like a tank. It's from around 1974. Only info I could find on the Kenwood is 65 watts per channel but I am not 100%. If the Kenwood is in clean shape and both work fine I would pick the Kenwood.
Thanks guys, really appreciate the comments. The were from two different sellers and I was able to meet the Kenwood seller this afternoon and bought that for $50. Pretty great condition and just hooked up some cheap speakers to verify it works, which it does - except A+B output option for some reason doesn't output on either A or B even though each of A and B outputs independently - I suppose I could DeOx the knob, though not a whole lot of scratchiness on the knobs in general. Checked offsets and L is under 10mV, but right is a little marginal at 35-38mV. So little out there on this unit that it may be a bit of a struggle to find out how to tweak the offset down on the right channel, but can run it like this and still be okay I think.
Here are some pics:
Will try these out with speaker taps on my Hifimans in a bit. (The back says 4-16ohm speaker range, but my understanding was that as long as it's not a tube amp, I could go higher without a problem, so I'm assuming I'm safe.)
Here are some pics:
Terrible pictures but I got a Sansui 9090 for free. Haven't listened through speakers yet but there is a very audible electrical hum through the headphones and the receiver gets really hot on the metal parts. How hot should it be?
Also, the lights will only light up if the selector switch is between aux and am settings.
Get it checked out before you use it. Sounds like you may have a short somewhere. Worth fixing though, definitely.
Terrible pictures but I got a Sansui 9090 for free. Haven't listened through speakers yet but there is a very audible electrical hum through the headphones and the receiver gets really hot on the metal parts. How hot should it be? I used an infrared thermometer and read about 115F.
Here's a picture of the inside of the KR-6060 I just picked up. The picture is big, so don't click on it unless you want to see a 12MP image.
While I have it open, I was going to DeOxit a bit, but I haven't done these two way toggle switches. Do I spray in the single hole in the metal on the bottom/horizontal surface, or the two black holes on the vertical?
And for the Power Dial (switches between Off, Phones, A, B, A+B), do I spray in the front gold portion (near the front of the receiver), or the gray plastic box nearer to the inside of the receiver where the power is connected?
Newbie questions, but I just don't want to spray in the wrong area and damage something. Thanks.
