Calling All "Vintage" Integrated/Receiver Owners
- Thread starter moodyrn
Skylab
Reviewerus Prolificus
180 mV is definitely too high. You will need to see if find the owners manual and see how to adjust it.
Rawrbington
- May 12, 2011
- Messages
- 1,225
- Reaction score
- 23
http://akdatabase.com/AKview/albums/userpics/10004/Sansui%209090%208080%20Service.pdf
Here's the manual
I'd check the bias as well.
Here's the manual
Rocko1
- Jan 27, 2010
- Messages
- 564
- Reaction score
- 37
Yeah, anything under 30 is good. Don't try to adjust offset unless you know what you are doing. Too valuable of a receiver.
Flume
- Jun 10, 2012
- Messages
- 23
- Reaction score
- 0
When I used the headphone jack I could here a very obvious electrical hum when the volume is all the way down. Capacitor issue? It's on both sides as far as I can hear... Probably going to hook it up to the oscilloscope tomorrow.
Kayrie
- Aug 18, 2012
- Messages
- 2
- Reaction score
- 0
Hey guys. Just joined because I love old receivers, fairly new to the audio world. I'm a college student so I don't have that much money to spend; anything within $150 would be good. I happened pick up an Onkyo TX-4500 MKII on eBay the other day and was wondering what are some of the better speakers/subs to pair it with. The kinds of music I listen to ranges from The Beatles, to Van Halen, to Yngwie Malmsteen, to stuff like Daft Punk, Justice (don't know what genera this type of music is called). I use a Fiio E7 as source to the receiver. Thank you for reading. Would Greatly appreciate the help.
I've read through some threads, but didn't to find a lot of informations on passive speakers, but rather self amped monitors/speakers.
wotts
- Oct 28, 2010
- Messages
- 857
- Reaction score
- 79
I'm not sure if you saw this thread: http://www.head-fi.org/t/552257/calling-all-vintage-speaker-owners/
I read through that and chose some speakers and started to learn what to look for.
Rawrbington
- May 12, 2011
- Messages
- 1,225
- Reaction score
- 23
thoughts on the Kenwood KR 9050?
i've got a chance to get one. just have no idea what its worth.
we've discussed a trade of my 8080 and a little cash. probably 100 bucks.
just don't know if its worth it
BmWr75
- Jun 20, 2008
- Messages
- 569
- Reaction score
- 20
I have one in near mint cosmetic condition and no known electrical problems. Probably unrefurbished. Sounds great. Paid $450 for it.
Skylab
I have never heard one, but the KR-9050 is a serious receiver. 200 wpc, weighing 50+ lbs. Massive toroidal transformer. I'm sure it's a nice piece.
Rawrbington
- May 12, 2011
- Messages
- 1,225
- Reaction score
- 23
how would you compare it to a Pioneer SX or Sansui 8080/9090?
captouch
- Jul 15, 2011
- Messages
- 581
- Reaction score
- 22
Uh-oh, looks like my Kenwood KR-6060 has a problem. Maybe that's why they sold it.![]()
First noticed it when I powered it up and it was plugged into the same power conditioner as the rest of my system. My other components were powered on and I was playing a CD through my other amp.
When I powered up the Kenwood, the display lights flickered and while they were flickering, static/power (imagine Frankenstein getting his energizing jolts) sounds came out through my speakers (powered by the other amp) (independent of the pre-amp volume control). Must have been feeding back thorough the power conditioner???
Once the Kenwood calms down (display lights steady and relay noise clicks), static/power sounds go away.
Moved it to another outlet and tried several times to power up the Kenwood. It always goes through this unstable period where lights are flickering (not sure what it's doing to the outlet since nothing else is plugged into the same outlet this time). Variable amount of time, but the lights eventually go steady, but I did see it go back into the unsteady state with the lights going back into the unsteady/flickering state before becoming steady again. Needless to say, I don't feel safe plugging anything into it at this point.
Update: Fixed it. The Kenwood, like a few other brands like Pioneers of similar age, uses an ALPS VR-5 power switch that is prone to failure due to black build-up on the contacts that leads to power arcing and those symptoms of light flickering, static, and delayed starts. Eventually may just not turn on I suppose.
Accessing the switch wasn't a big deal on the KR-6060, though I understand it can be more involved on other models like some of the Pioneers that require front panel disassembly. But using some fine grit wet/dry sandpaper (1500 in my case), I was able to get the junk off and now it powers up consistently and quickly without any light flickering.
Just wanted to update in case any others are having start-up/power-on problems on receivers using that same ALPS switch.
BmWr75
- Jun 20, 2008
- Messages
- 569
- Reaction score
- 20
I have not listened to it enough through one set of cans to be able to say. It is rated slightly more powerful than a SX-1280 and 2X+ more powerful than the 8080. How that makes a HP sound probably means nothing.
Rocko1
- Jan 27, 2010
- Messages
- 564
- Reaction score
- 37
Nice job. I would treat all switches with Deoxit spray. It's simply the best contact cleaner/conditioner around.Update: Fixed it. The Kenwood, like a few other brands like Pioneers of similar age, uses an ALPS VR-5 power switch that is prone to failure due to black build-up on the contacts that leads to power arcing and those symptoms of light flickering, static, and delayed starts. Eventually may just not turn on I suppose.
Rocko1
- Jan 27, 2010
- Messages
- 564
- Reaction score
- 37
The Kenwood is made from 1979 to prob. 1980 or 81. The Sansui is 1977 or so. While the Kenwwood is more powerful at 200 watts per, I prefer the Sansui. Seems better built and looks more the part of vintage, just my opinion. The 9050 is a freakin beast though. The offer seems fair if it's in great shape and everything works.
