The left driver of my HE-6 just went out
Sorry to hear that.
Check my video review of the HE6 and then you will understand why I sold them.
Sorry to hear that.
Nope I've been very careful about that. My 500's are running at the same level with no issues. The driver went out when I tried to adjust the bass.There is always the possibility of loose connection. If you have a meter you could ohm out the right and left sides to check for a difference or an open circuit.
I would think the only way you blow the driver is if you are listening at the threshold of pain.
Two thumbs up on that! I find that true of most HPs.
^^ First you must understand that you cannot use the Grados in public, as they leak like a sieve and isolate not at all. It that's still OK with you, I recommend the SR 60e, which is the most improved to my ears with the change from the i to e series. It's the best bang for the buck by far.
Hello, can anyone help answer those question. Is the Marantz 2230 strong enough to drive the Sennheiser HD650 properly? Thanks.
