Hi all, I recently received a FUN for review and have a strange issue going on... hoping someone can help. The amp sounds great sometimes (I have used both the stock opamps and V6C with good results), but I am finding an intermittent issue with a significant noise through the system using either active speakers or headphones. The noise sounds like power noise - it's consistent in frequency with a slight rhythm to it - like a low buzzing noise.
At first I thought it was an opamp issue because I noticed it after first installing the V6C, but switching back and forth has proved that both sets of opamps can be silent or can exhibit the noise. I've tried plugging into different power circuits, trying the amp with no source connected, and with / without the active speakers connected to the pre-amp outputs. Last night the amp was working perfectly with no noise (using V6Cs), but when I switched it on this morning it was pumping out the noise again.
By the way, my other gear is all unaffected (Bottlehead Mainline, Gumby, iFi Micro iDSD)
Anyone got any ideas what might be happening?
