Jazz1
I own the Px and though I like the sound, there have are several ergonomic things that annoy me.
The headband causes a sore spot to develop on my head that becomes unbearable after 30mins. Also, the bass quality and quantity is very dependent on getting a good seal. However, that seal is extremely easy to break; wearing glasses is out of the question, and also, every time I move my head downwards or backwards (even slightly), the seal breaks and I lose the bass. I need to be staying perfectly still with my head in the same (very upright) position to get good bass. For a headphone that is designed to be for travel usage this is definately not ideal. Does the PX7 resolve these issues?
Also, for a wireless headphone I believe a very secure fit/clamp such that moving your head about doesn't cause the headphone to slip and slide about out of position on your head is very important. Is the PX7 a secure fit?
I have found the PX7 to be much more comfortable to wear for long listening sessions than my PX headphones, say for three-four hours at a time. I could keep on going beyond 4 hours I think, very easily. I will say the pleather cups would probably be too warm in warm weather.
I do wear glasses, but they have flat, metal temples. So far the seal of the ear pads doesn’t seem to be disturbed as I move my head. The clamping force versus the PX is less, but that is part of the greater comfort level offered by the PX7. I did find I could get a tighter fit by adjusting the ear cups further into the band. Meaning if I was going to be bending over a lot I could get a tighter fit. Of course there is some comfort sacrificed by doing this. My old PX headphones certainly had more lateral clamping force against the sides if my head I don’t do anything but sit, walk, or lay down in over the ear headphones, so I don’t know if my evaluation is useful for active people.
I finally got to check out the noise reduction in a coffee shop today. Loud music playing in the coffee shop, and conversations going on all around me. I was very satisfied with the NR performance. Did it make external noise fo away completely? No it did not. But my music remained enjoyable. BTW I have yet to find headphones as noise deadening as my Bose QC20 earbuds. Meaning the NR is like going into an airless room. If I were flying with screaming babies the Bose be a better solution for loud, constant noise. But you would sacrifice music quality vs. the PX7.
In the coffeeshop today coffee beans being ground did get through the music I was listening to. I did have the B&W headphone app. set on auto, and then on heavy. Auto seemed to respond very well to the changing noise level in the coffee shop without the need to mess with low and high adjustments.
