Denkmal
Sorry mate. Just tried with my iPhone 11. Doesnt work, headphones do not show up as a headset or anything.Someone must have tried this. Pleeeeze
Personally I am not sure how this is even a use case.Thanks. Jeez, that’s a real pity. Not sure how or why that can’t work. Anyway.
Will perhaps look at the THX Onyx.
You can't run these 'passively' because they don't work unless they're powered. My B&O H95's can run passively which is nice but I typically run them when I need wireless portability. Am I missing something here?Personally I am not sure how this is even a use case.
Thanks Roger, but I believe the upper “Hi-Res” tier from  MUSIC will require some wired hardware. As per the below:Apple Music on the phone -> bluetooth -> PX7?
You'll need to check which is the best codec that both support.
well, neither AAC, AptX or AptX HD are ”lossless” codecs. But I doubt you would be able to tell the difference on the PX7.1. CD Quality (16-bit/ 44.1kHz, standard lossless quality)
2. Lossless (24-bit/ 48kHz, better than CD Quality)
3. Hi-Res Lossless (24-bit/ 192kHz, requires dedicated hardware)
Tier 1&2 should be achievable over AptX over Bluetooth straight to the PX7’s built in DAC.
I think you have to use camera adapter, the one with usb c and lightning ports. At least it worked with px…
Personally, I am looking to get the maximum lossless digital stream from a  device (Mac & iPhone) straight to the inbuilt DAC of the PX7 (where I believe the max handling is 24b 96k. I’m not too phased about it not being totally passive. From what I’ve read, even if you use a Lightning to USB dongle, then a dongle DAC (Dragonfly, THX Onyx etc), then 3.5mm to 3.5mm (ana), the PX7 digitises this analogue stream again before delivering in ana to the drivers. To me, this is overkill, and has redundant elements.
Dude, I have IEM's and a bluetooth DAC/AMP from ESS that blows away any wireless full-sized headphone. And reading your post here just tells me you need to be patient for the wireless tech to catch up to the sound produced by wired sets. I want a sports sedan that sleeps 8, does 0-60 in 2.5 seconds, and gets 99 mpg. But then there's realityPersonally, I am looking to get the maximum lossless digital stream from a  device (Mac & iPhone) straight to the inbuilt DAC of the PX7 (where I believe the max handling is 24b 96k. I’m not too phased about it not being totally passive. From what I’ve read, even if you use a Lightning to USB dongle, then a dongle DAC (Dragonfly, THX Onyx etc), then 3.5mm to 3.5mm (ana), the PX7 digitises this analogue stream again before delivering in ana to the drivers. To me, this is overkill, and has redundant elements.
