alexandros a
With Hibi R3 it pairs quite well....i can confirm that much....Anyone tried to pair the dm6 with the hiby r3, xdp300r and fiio m9? Which dap does it pair well?
Sorry should have be more clear, DAP with balanced output (2.5mm preferred)
I run my Dm6 through the q1 as well, having it connected to my Huawei p9 being the source and I have no constant noise whatsoever.Hello world!
I’ve been reading on this forum for ages but never been a member. Pls don’t burn me Thanks for letting me in.
I have ordered the Fiio M9 (Swedish store) for my DM6(ordered from AV store on AliExpress). I did a lot of research before settling on the M9, it has a decent battery, with a ok speed OS. But the 2,5mm was made me putt the trigger. The r6 pro is WAY to expensive for me, else I would get it once it hits the market.
I do have the FiiO Q1 MKii atm and I travel a lot and need the juice on my phone for actual work.
With the FiiO Q1 I do have a constant static noise on both the 3,5mm (one included) and balanced 2,5mm. I did get a cable with a mic on it and it’s the same problem with the Q1. I’ve tried both on my Android (Samsung S9) and on my iPad Pro. I have the same problem on both devices. I have no problem directly from the iPad or Samsung with any fo the 3.5mm.
I did however order a new 2.5mm in silver as the BVGP 2,5 is not the best quality if you ask me.
I’m betting back to Sweden the 12th and will pick the M9 up then, I’ll let you know how it is.
Hello, what you mean saying 2.5 bgvp is not good quality.
You mean that 2.5 balanced cable they are seling? New cooper version seems quite good. Dont know about silver.
fHello, what you mean saying 2.5 bgvp is not good quality.
Thanks for showing up. Now i understand what you mean. So basically regarding cooper version it should be made by the same quality standart. But this original version doesn't look very good made for shure.
R6 and R6 Pro share the same SOC, the same amount of Ram and both run Android 8.1 - despite being a bit older why should the R6 lag and the R6 Pro not so?
Laggy? The FiiO M9 will definitely give bad experience if you want a fast device. Its hardware specs are terrible to run android. I used to have it and sold already.
Speaking of cables, my NICEHCK Pure Copper Cable arrived. Looks amazing. Best cable I have currently. And it's a thicc boi. #Respect I'm not even gotta bother with the cable that comes with my DM6, unless I get lucky with their new OCC cable.
But one user Zikarus there posted as i understood quite happy with such cable as this: https://de.aliexpress.com/item/NICE...l?spm=a2g0x.10010108.1000023.5.692f6058q1oVgz . It should be the same as you have recomendedHmm... that sounds bad. I haven't received my DM6 yet, so I haven't tried the cable with them. It might be related to the cables mmcx outer ring being made of 2 parts (the cylinder is cut in the middle), which got me excited the first time, because if the mmcx connector breaks, it will be easier to get it out of the bud, because there would be two pieces, unlike the cable that broke inside one of my TinAudio T2s, and completely f**ked it up. But, now that you reported that, I think it might not be a good idea. I will let you guys know what happens when I get my DM6 (by the looks of it, I might get it as early as February, if Michelchan misses the January 8th mark again), and I will retract my recommendation of the cable if the problem is systematic. It might be a problem with the plug on the DM6 too, soo... If you have other IEMs with mmcx, have you tried the cable with them?
