- Jun 26, 2001
Scrap what I said above - new favourite, fills out the mids nicely - Sennheiser prod code 561099 - Large CX500 style silicon tips - work a treat
Can anyone recommend a wide bore foam tip? thanks
I made my own mod of the symbio foam inside the final audio tips. Those work great for me. If u r not a fan of stamdard eartips, i reccomend getting a custom tip from jomo and be done with it. I also feel that tips are limiting, thats why i use customs.is there nothing new to top the tips we already know, after trying so many, without a doubt the best so far a old sony silicon foam filled no doubt then others come along
the symbio I feel its silicon is too slipery, and the foam from inside is a bit hard compared to the amazing sony silicon foam filled ones
I find it ok as the seal comes mostly from memory foam. Too sticky tips like the aurisonics tips are hard to insert, but once they are in they seal too welli think one big mistake with tips is the silicon material is the type that is slippery as its so smooth, I think the silicons should not be so smooth and use patterns that help in keeping the seal and be more of a sticky type material
Apparently not soft enough for my ears. I would recommend trying final audio type e insteadI use SpinFit and they’re pretty soft
I do believe they can easily be found on Google. Alternatively if u r from the us, u could look on the official site or contact them by emailPlease, where one could find final audio type E ear tips for purchase.
