did u try them, i like to try all tips
but so far the red ones u told us bout are amazing, they are like glue to the ears and seal so dam well
Nope , didn't get a chance to try those , previously before the Red ones , I'm on foams with some generic silicone ones , I didn't get a proper fit with any sizes on those silicone and the foams doesn't last long enough for me , I'm sweat + oily skin .
I chance upon the Red tips when I was searching for the original HTC tips ( also in red ) which comes with my mobile headset , the Red tips are equally good to those of original HTC tips , both share the samei size diameter , also in red . Only difference is the HTC tip are softer . As regards with comfy and sealing , both are identical .
I don't know how many actually bought and try it after I had share out , till now , only you and Jmills are the only known ones here whom had confirmed to me that it's good on you both .
And the last I spoke with that seller , he told me he had something close to 30 orders on that Red being shipped out after my advice to him to list the tip up in the store for others to have a chance to buy and try it for themselves .
But then , too bad , since then , that seller has gone MIA . He had close his aliexpress store .
That's not as if I had a better alternative to offer, mind you! But yeah, the "game" is often,
If you live in Europe, be prepared to pay a lot more than if you lived in the States.
I've recently ordered a few different tips on AliExpress. We'll see if there's one set I like.
Exactly bro , very often we see shipping cost is 3-5 times over the item itself.
Aliexpress is a very good hunting ground for unbrand tips , over there I'm lucky enough to find a very good tip which works flawlessly on me without spending tens / hundreds of dollars in search for a ideal fit / seal .
Technically , the search for a ideal tip which actually seal + proper fit is over . Until I wasted up all 8 pairs I got at hand , will then I go hunting . But theoretically the 8 pairs can probably last me of a lifetime I'm pretty damm sure about that ... But not so sure if my iem can last that long
There's a lot of varieties to choose from + cheap + free shipping in most cases in alixpress
I'm sure you'll get to find some workable on you .
