goodvibes
- Dec 28, 2009
Unless I'm mistaken the DX50 is using android.
Thanks. I guess they kinda know it from the DX100 but it seems like a lot of code for this.
Screen is way too sensitive to the touch and when scrolling music, I end up inadvertently playing a track.
Other than those, no show stopping bugs.
This is a good example of having to get used to how something new works. I had the same problem with inadvertently playing a track when I wanted to scroll, but figured out that I was used to using a very "soft" touch while scrolling to keep from triggering playback and the DX-50 likes a firm touch while scrolling and a light tap to play. Now that I am used to it, it makes sense to me and I rarely trigger play when I want to scroll. So here's the question, is this a "feature" or a "bug"?
Depends on what you are used to and what makes intuitive sense TO YOU. But really, it's just how the DX-50 works and something to get used to.
This is an example of where a comprehensive e-manual explaning how the unit is designed to work would save Ibasso a lot of headaches, in my view...
It is a bug. Seriously, I have the same problems. I have many DAPs and none exhibits the same touchscreen sensitivity (in a bad way) as the DX50.
"Damaged my hearing" LOL try firing off whole 20-round magazines from an AR-15 without protection like I did many times, and then you'll start to damage your hearing. I can still hear clear up to 17.5 KHz, despite this.
Yeah and last time I put my head in the oven and I was only partially burned so honestly I do not know what the guy is complaining about !"Damaged my hearing" LOL try firing off whole 20-round magazines from an AR-15 without protection like I did many times, and then you'll start to damage your hearing. I can still hear clear up to 17.5 KHz, despite this.
Originally Posted by In Over My Head /img/forum/go_quote.gif
I fail to see how your disregard for the potential damage you inflected upon yourself is in any way relevant to OP's concern for the potential harm caused through no fault of his own.
But then again, to me the DX-50 works "right", light tap to play, firm drag on screen to scroll. So you can't make everyone happy, I guess.
Kevin
I had the volume thing happen to me several times but it hasn't occurred since 1.2.
We may have a deviation from your player & mine. I'm from the first batch and I notice that our units tend to have more problems. I'm glad you are happy with yours though but, none of my others player exhibits this much of bugs.
Maybe because 20-round magazines from an AR-15 without protection are far louder than a DAP and a pair of iem's?
But there is a solution right hear and now for this issue if it worries you. If you must adjust the volume while listening to a track, pause the player, adjust the volume, make sure it stopped where you want, and unpause the player.
Yes, I understand that Ibasso should (and, if they can replicate the problem, probably is trying to) fix the problem. But till then, please no whining that "I shouldn't have to do that" if it really worries you. I have never had the "fade to max" problem myself, but not too worried either way...
Kevin
