- Jun 22, 2011
I have my hopes up since the galaxy s3 can reportedly power the odac.
The odac is bus-powered, right?
Kojaku
I would like to know about your impressions, comparison between these two combos, Dragonfly + C421 and ODAC + C421. I have already known that Jude said the amplifier of Dragonfly is just so so not good or not bad when he compared to some low-end amplifiers. What I am truly interested in is about the quality of the DAC of Dragonfly. Thanks!
So this is interesting... I tried out the Dragonfly -> O2. Oddly enough, I'm not finding quite as much difference as I was expecting vs the Dragonfly by itself. As in I don't know if I could really pass a blind test. This was both with the EPH-100 and Thunderpants, which today trying out they seem more palatable than initial impressions... now they don't really seem to be lacking with those.
I had much the same experience plugging it in as a source to my L3. While the L3 makes a significant difference used with my Fostex HP-P1, it didn't seem to do anything for the Dragonfly. However, with complex music the situation might be different, as the Dragonfly can get a bit blurry with, say, dramatic orchestral works.
Ive just received mine!!
Im simply loving this little thing!!
Quick tested some headphones here, and it sounds so good!!
IMHO the macbook air heaphone out is crap, now using dragonfly is a diff. history.
Tested so far,
IE80, FX700, PortaPro, ESW9, ES7, K701.
All sounded good, except k701.
I could measure the output impedance. Anybody could help ( should it be done turned on, off, playing ?)
Have you tried any Hi-Res files? I get a kick out of the color indicating the rez....I am enjoying a lossless file at 96K and the Dragonfly is Magenta....I like it.
Not yet, so far just 16/44.
Tomorrow I plan to listen to some music from HDTracks.
Just one question, If you play a "silent" track and change the volume, can you hear some clicks? Im asking that because I can, dont know if its an issue or its just fine.
