BenF
- Jan 22, 2013
I don't see how this helps - it's not like DF is too heavy and bends under its own weight.
it doesnt bend for sure but still relieves stress on the USB port
Does anyone know if this will work with a Playstation 4?
I know my USB headset works, so I'm assuming that this will too.
No one is pointing a gun to your head, making you buy an extension... We just suggest one to extend the life of your components. The Dragonfly's male never inserts finally into the female. There also is a good bit of weight that can lead to damage. The reason for the DragonTail over a cheap USB extension is that it's usually $16 and uses AQ's carbon line (solid core copper). Believe cable smoke or not... A good cable is reliable. The $1-5 cables always end up dying on me, eventually.
Sorry if I come off snooty. But if you use one long enough (or read through the entire thread) it makes way more sense.![]()
What's so great about the dragon tail? Just curious.
It prevents damage to the dragonfly and USB port.
Hey guys, little problem.
I just got home from work and sat down at my PC and now my Dragonfly is not outputting any audio.
I have gone through and checked to make sure the settings are correct and nothing is working.
When I try to play a test tone in windows it says that it failed to play a test tone and when playing something through music bee it tells me that there is a Bass_error_handle.
It worked 12 hours ago =/
Sorry to beat a dead horse but even searching didn't get a solid answer. @mrscotchguy
seemed to have the closest thing but not a definite yes.
Does the Dragonfly V1.0 or V1.2 work with just an OTG cable to a Galaxy S3?
