tme110
- Jan 21, 2011
even more interesting and def good to know. does kinda make sense (since it had to be modified)
Got some bad news. Looks like once the AP1 has been modded, it's not designed to work without the PP. Tried to unhook the AP1 from the PP and connect it directly to the Vaunix/laptop. The bitrate display just flickers, and the error message "No Ext Power" appears on the bottom of the AP1 screen in red letters.
Aaaaaand now it's doing the clicking thing again. I'm not sure what it is this time.
Check that the firmware is current via the menu. Should be v1.9. This is a know issue with previous versions of the firmware.
EDIT: Mine did the same thing on an earlier version of the firmware.
So, both the PP and the AP are current? PP firmware should be v1.9, the AP firmware should be 1.2? If you are current with those, then there's something wrong. Call Phillip.
I'm a Mac user, so no drivers necessary.
I had weird issues with the PP seeming to drop dead, which Philip instructed me how to reset. Since then it has been fine, but it might not have liked being plugged and un-plugged at some point. Just brought out some very nice recordings made by Kostas Metaxas in Melbourne and enjoying the greater sense of space and pinpoint imaging with my whole kit.
I know how much you guys like pictures, so here's a quick teaser:
Will be using AP1/PP -> Benchmark DAC1 USB -> Gilmore Lite w/ DPS -> Sony Qualia 010.
I don't that Y-cable needs to be that expensive - I was going to DIY one (just need to calculate the impedance to be close to 90 Ohms). One could also just butcher a wirewold etc by running a stanley knife down the middle and reterminating the ends - it wouldn't be pretty but it would be a cheap[er] Y-cable with sure 90 Ohm impedance. Perhaps like the starlight that came with the AP2/purepower
personally though I plan to start from scratch and just aim for within USB spec tolerance of 90 Ohms - I just need to figure out how the shielding affects the impedance - or I could just copy the gauges used in any cheap to-spec USB cable.
