Dear all,
We've readied a new build for testing, unfortunately the App Store will be closed to updates from 23-27 December.
In the meantime, you can install the new build for testing as follows:
1. Go to https://beta.bugly.qq.com/gqqn on your iPhone/iPad browser.
2. Tap on the
![](https://www.head-fi.org/attachments/1780519/)
"download now" button. (the app itself is localized for English and stuff)
3. In the prompt that appears tap on "Install".
4. The Hibymusic app (or a new copy thereof) will appear on your desktop. If you tap on it at this point, you will see an "Untrusted Enterprise Developer" prompt appear preventing you from running the beta.
5. Go to Settings on your phone / pad, tap General, then Device Management (3rd item from the bottom). Tap on "Dongguan Haibei Information Technology". In the next screen tap 'Trust "Dongguan Haibei Information Technology Co. Ltd.", then Trust.
6. You may now run the HibyMusic beta.
This beta is improved over the current Testflight build, so Testflight users can also try it. Beta app improvements:
iOS 2.1.1(3786):
1. Added option to proceed directly to mailbox on forgetting password
2. More iPad optimizations
3. Improved sorting algorithm
4. Updated third party login
5. Improved cover art display
6. Improved folder / album playthrough logic
7. Lyrics time adjustment now applies to each song separately
8. Fixes iPod music scan crashes
9. Corrects display of track time info in specific situations
10. Fixes crash caused by lyrics display under iOS7
Looking forward to your feedback!
Best regards,
HibyMusic
