timb33
- Jan 9, 2012
I use an ipod touch and an E11 w/ the L9 LOD cable, the size isn't a big deal, but my budget is, I don't want to spend more than $100 on an amp. Is the ZO2.3 better than the E11? Thanks
What player are you using the PRO700MK2 with? For me, my primary DAPs are my Cowon Z2 and iPod Touch. With both, I usually set the EQ for bass boost. This probably adds about ~5db of bass quantity which greatly helps in bringing the PRO700MK2 to life.
If you feel that the E11 is a tad too big for you, try the ZO2.3. It's really small, but it manages to boost the bass to huge levels.
