Prakhar
- Jan 3, 2012
Can I use them as portables? Does the headband stick out from the head, or do the earcups stick out from the head?
how long do they take to burn in ? mine sound muddy i used them for about 20 hours
If only they had the same headband style (close to the head) like the VModa M-80/M-100...for my taste they look very bulky/akward on baldies or low fade hair styles (like me)
I heard that you could solve the earpad problem by sticking a few cotton balls inside the stock pads.
These aren't as bassy as everyone says, I have a FiiO E11 hooked up to these and then they become monsters, but stock they are nothing to brag about.
I have to agree with this. To get the bass I want, I have to turn up the bass on my E11 to 2, that's something I didn't have to do with my other basshead cans.
Yeah, I also have to turn the bass boost up to a 2, and it kinda sucks that you need an amp at al times for them to preform as expected
What about EQ-ing with your DAP? I'm sure you can get some decent bass quantity levels by boosting the low-end with a good EQ.
The PRO700MK2 is a really good basshead can in that it retains its punchy, clear bass even when boosted with an amp/EQ. Try switching the stock pads with M50 pads. The bass quantity will increase a bit.
I have the m50 pads but for the best bass it can produce you should get an amp, I never use these without one. I don't use any EQ at all by the way
