That is correct. I2S (or Interchip signal) was designed as communication between chips, not between chassis. As I stated previously, if done with USB and the I2S is decoded at the receiving end inside the DAC then it's fine, and the proper way to use I2S. But I don't think that's what is being discussed between BigMac and Audio-gd. They are looking to connect I2S via two chassis either using a DIN or an HDMI cable, from what I can tell. When you do that, varying cable lengths will have a much greater affect on the SQ than even comparing a cheap S/PDIF cable to a well made one -- which is what I've been told from the company who modified my Transporter, as they have experimented with various implementations of I2S and always found it to fall short unless it was being done via USB and decoded at the receiving end inside the DAC.
The RE7 sound quality has proven to vary dramatically between DSP-1 module versions, and that should be stabilized before they jump into I2S transmission in my opinion. Not everyone is or will be using an Audio-gd transport, and if adding I2S will in any way compromise the quality of S/PDIF or AES/EBU then it should not be done.
If you counter that with the sound logic that no cable(s) will significantly impact sonics ( copious lengths, very high impedance obviously not included) then I2S is fine... and so are other cables.
If a certain cable or signal approach causes you significant anxiety then avoid it I suppose. Other than that both methods are equally valid until something/someone can prove/demonstrate in a repeatable fashion I2S degrades significantly when used as an inter-chasis medium, or that eliminating SPDIF chips and ETC actually benefits sonics.
Seems to me though that eliminating electronics would be a great thing so I2S could really be the bees knees but until people stop using stupid connectors, or proprietary one it is a lose lose situation for the consumer.
Also, I think any company's statements towards cables are just as valid as anyone else trying to sell you their products... even class acts like Jan Meier, Kingwa have to make money at the end of the day and cables are a very easy way to do so (too easy). They make money by "properly addressing peoples needs"... so if people have a need they supply something. And I mean this is the best possible way with respect to Jan and Kingwa... they are some of best with regards to snake oil in the business. Well, for those who have not completely cut it out of their practice.
Were I a less honest person I would probably have quit school and started up a cable company a while ago. There are few other
legal was to make big money fast like that for the average Joe.
Either way, the Ref - 7 sounds pretty damned good no matter what you feed it... as it should.
My Xonar STX, oppo universal, and PS3 all sound sublime when I use them with the Ref - 7. RCA to BNC, RCA to RCA, or optical, they all sound great. And it might make sense if you consider they are all supposedly de-jittered to 50ps if my understanding is correct.
