kschiu
- Apr 17, 2012
For the fun of it I tried a 3 meters i2s, I still got music. I did not spend too much time checking the SQ though...
Yes, Kingwa said using flat ribbon is better, and to try different types for comparison. Make it short though.....
I have bought few flat ribbon cable for test, it is worst than the normal web cable, then I cut it ,fought it is each two wires intertwist configuration .
I have try the longest I2S transfer with 5M cable still working, a bit worst performance by instruments test, slight worst on sound.
Sorry Kingwa I had mixed it up and misrepresented your i2s cable connection suggestion. Thanks for correcting it.
