les_garten
- Nov 6, 2008
It wasn't someone it was me! These threads sometimes get out of Kilter quick, so let me clarify a few things I mused before.
For a Class A circuit, I don't think 120F on the heatsinks is hot at all. It feels like a Class A circuit. If 120F bothers you, you might want to avoid anything biased Pure Class A. They only get hotter than 120F, not Cooler. YMMV.
I mentioned the skips, I'm not sure of the Etiology of those skips yet. I'm looking for them to happen again so I can finish troubleshooting. Haven't seen them again. My REF1 has been running solid for about 5-6 weeks. My first idea was that it was my Computer/Source. I rebooted and it was still there. Let's not tar the REF1 with that one yet. I didn't finish the troubleshooting on that one.
Also if the skips are to be attributed to the REF1, it is entirely possible it is related to the Memory issue discussed before where I noted distortion and image shift when the REF1 is run for 7 days or so. May be the same issue manifested differently.
Just as a side note. Because I was interested in this during the development stages, I had asked Kingwa if he could install a TTL Serial Comm port on the DSP for monitoring. I never got that point across to them, they either didn't understand or didn't want me mucking around in the Altera Chip.
But I just noticed a Header on that board that looks like it is a TTL header. I may revisit this. It would be nice to debug the Chip while it does the image shift thing.
Originally Posted by bobsmith /img/forum/go_quote.gif I would not say "clearly." All we know is that someone reported the unit was hot, and that it was skipping - we do not know which is the cause or the effect. We do not know whether the heat was causing the skipping, or whether the skipping indicated a fault that was resulting in extra heat. We also do not definitively know that the skipping was in any way related to the heat...they very well may be completely independent. For example, the skipping could have been related to the voltage fluctuation issue rather than temperature. All I am saying is that it is not a great idea to draw general conclusions from a single data point... |
