1 - ....I'm curious, why did you swap out the BB IC OPA's ? They are only used (IIRC) to control DC offset (servo duty) and keep that offset at 0.
2 - How do you like the Legenberg wire ?
3 - I think since the BG and Mundorf caps are very similar in construction the burn in period for my mod may actually be closer to 700 hours than the usual 4-500. I can wait but hopefully this number is closer to 500 for my electricity bill's sake.
4 - Oh what was the issue that had your R channel MIA ? Good to hear you have it fixed.
Peete.
Hello !
1 - You all guys are right. Kingwa told me the same thing. OPA in this position (DC servo) are not important.
But I had the SUN V2 in hands and I'm a curious guy.
So I wondered to myself "why not to try them". The only risk is to loose 10 minutes.
And you know what ?....... I will never remove them.
Subjectively, the benefits are more resolution and more tensed (?) bass.
I would like to put the REF1 on a mesures bench before and after each tweak, but I don't have one. So I only talk about subjectives sensations.
The only thing I would recommend to REF1 owners is to try the SUN v2 and make your own opinion.
2 - I have choosen the legenburg wire because of is geometry,which is supposed to have advantages again round wire. But I have not notice any significant change. But I will continue to use it for the good conductivity of pure copper.
3 - No burn in for me now, as the replacement of the caps have given to me what I wanted. Details are easier to ear (it's was not bad before) but without being fatiguing. And my god, what an impact
On a disk I know well (Hadouk trio - air hadouk:
http://www.amazon.fr/Air-Hadouk-Trio/dp/B003162RFQ/ref=sr_1_1?ie=UTF8&s=music&qid=1278625970&sr=1-1) I was surprised when a blow of percussion drum came.
I don't know if a streaming listening session will give to you an idea of what I want to say.
4 - I have redone the solder points of the new caps and the sound came back after I replug the dac two or three times. So I suppose it was the problem, even if they was no sound after the first replug.
Djilbe
