My R2R 1 is for sale, Europe only. I found out that my system is not resolving enough....
Audio-gd R2R DAC Thread
Hi - do you think it’s the R2R-1 that’s not resolving enough or other parts of your chain? Which headphones do you use? I find my R2R-11 very resolving so would be very surprised if the R2R-1 was less so. What have you compared the R2R-1 to that was ‘more’ resolving in your opinion?My R2R 1 is for sale, Europe only. I found out that my system is not resolving enough....![]()
It´s not the r2r 1, it is the rest of my system. I have Audioquest NightOwl... I haven´t heard anything more resolving, r2r 1 is the best, but not worth to keep in my low chain. You have better headphones...
New R-28 just announced. Impressions thread here:
https://www.head-fi.org/threads/audio-gd-r-28-impressions-thread.882043/
- Jul 30, 2015
Looks like there's a sale going on over at Audio-gd for their 14th anniversary. The 5% discount is about half-off shipping to the US. Turns out I didn't need much of a push to order an R2R 11. What I do need is some NOS DAC love for my living room, and the 11 fits the bill.
Hey TiborM,
I am also a Nightowl Carbon owner. I have created an EQ set to use with each set of pads on this headphone. Both of these EQ sets take the Nightowl to the next level in sound quality. I think you will be impressed. Let me know what you think.
EQ set to use with the ultrasuede pads:
Pre-Amplifying: - 2
50Hz: + 0.5
63Hz: + 0.5
80Hz: + 0.5
200Hz: - 0.5
250Hz: - 0.5
315Hz: - 0.5
1.6kHz: + 0.5
2kHz: + 1
2.5kHz: + 1.5
3.15kHz: + 2
4kHz: + 1.5
5kHz: + 0.5
6.3kHz: + 0.5
10kHz: + 0.5
16kHz: + 0.5
EQ set to use with the pleather pads:
Pre-Amplifying: - 2
80Hz: - 0.5
100Hz: - 0.5
125Hz: - 1
160Hz - 1
200Hz: - 1
250Hz: - 1
315Hz: - 1
400Hz: - 1
500Hz: - 1
630Hz: - 0.5
1.6kHz: + 1
2kHz: + 1.5
2.5kHz: + 1.5
3.15kHz: + 2
4kHz: + 1.5
5kHz: + 1
6.3kHz: + 1
8kHz: 0.5
10kHz: + 1
16kHz: + 1
Pre-Amplifying: - 2
50Hz: + 0.5
63Hz: + 0.5
80Hz: + 0.5
200Hz: - 0.5
250Hz: - 0.5
315Hz: - 0.5
1.6kHz: + 0.5
2kHz: + 1
2.5kHz: + 1.5
3.15kHz: + 2
4kHz: + 1.5
5kHz: + 0.5
6.3kHz: + 0.5
10kHz: + 0.5
16kHz: + 0.5
Pre-Amplifying: - 2
80Hz: - 0.5
100Hz: - 0.5
125Hz: - 1
160Hz - 1
200Hz: - 1
250Hz: - 1
315Hz: - 1
400Hz: - 1
500Hz: - 1
630Hz: - 0.5
1.6kHz: + 1
2kHz: + 1.5
2.5kHz: + 1.5
3.15kHz: + 2
4kHz: + 1.5
5kHz: + 1
6.3kHz: + 1
8kHz: 0.5
10kHz: + 1
16kHz: + 1
sinae
- Dec 2, 2007
Placed an order for the R2R-1 tonight. Looks like the Mimby's on its way to work! I'm honestly not expecting a huge upgrade, as the mimby has been mighty impressive, but I'm looking forward to having the full stack that will use both DAC and amp at their full potential.
please write a comparison since the mimby multibit that i had sucked balls
sinae
- Dec 2, 2007
Anybody can measure crosstalk SNR?
- Jul 30, 2015
The Mimby and the R2R 1 are so different it's hard to make a fair comparison, but I'd take the R2R 1 over the Mimby in all cases except for maybe studio monitoring or other professional applications.
The mimby doesn't sound like balls... but whatever, it does sound better in conjunction with the Eitr.please write a comparison since the mimby multibit that i had sucked balls
I already wrote a brief comparison and even though I haven't turned the mimby for a while I imagine it's still accurate.
My R2R 1 arrived a few days ago and I couldn't be happier with it. It's a marked improvement over my Mimby+Eitr combo. First basic impressions are that it's tonally very similar to my peasant ears, but is very noticeably more resolving. It also has a higher output voltage than the Mimby, so I'm a few notches lower on my NFB-1 now. I've tried it mostly via COAX from my Eitr, but noticed no drop in quality when using USB directly from the PC (note: I got it with the USB Isolator option). Also, NOS mode does sound warmer to me, but it's not night and day. I'm more than happy with with the default 8x OS mode.
Long story short is that this combo sounds fantastic together and works flawlessly with my PS4 Pro via Toslink.
Hello Friends, Is there any good usb isolator that works well with R2R - 2? there are couple of products in the market, but not sure which one is compatible with R2R -2.
Pharmaboy
You really should distinguish between devices that just isolate (ie, USB input & output) vs devices that convert (and to a degree, also isolate. I use one of that latter devices because I found that I prefer coax input with all 3 DACs I've tried it with vs USB straight in.
My S/PDIF converter is the Musical Fidelity V24/192 (no longer sold). It converts a USB input to coax output. With that I use the very fine sounding Oyaide DR 510.
If you're going to play back DSD or anything above 192k (including using software such as Audivana Plus) to upsample, you'll need to use the USB input. I've been using the USB input on the R-28 directly from a Mac Mini without any problems. I'll talk about experiments with the different inputs and USB isolation in my review though, once I've had enough time to play around.
My ears aren't well refined, however I've not been able to hear any difference between USB and COAX (+Eitr) with my R2R-1 (which has the USB isolator upgrade). I'm looking forward to hearing about said experiments.If you're going to play back DSD or anything above 192k (including using software such as Audivana Plus) to upsample, you'll need to use the USB input. I've been using the USB input on the R-28 directly from a Mac Mini without any problems. I'll talk about experiments with the different inputs and USB isolation in my review though, once I've had enough time to play around.
Looking forward to your review... to me its worth investing if the difference is audible.If you're going to play back DSD or anything above 192k (including using software such as Audivana Plus) to upsample, you'll need to use the USB input. I've been using the USB input on the R-28 directly from a Mac Mini without any problems. I'll talk about experiments with the different inputs and USB isolation in my review though, once I've had enough time to play around.
