Some quick impressions having the Phoenix for a couple of days now.
I tried something different and instead of jumping into straight AB with the Lehmann, I just listened to the Phoenix as it burned in. I paired it to the Reference 7 in balanced mode and quickly made a pair of 2 metre ACSS cables with cheap four conductor insulated microphone cable from local electronics store...because 1 metre was too short. For this comparo I fixed the the Bryston BDA-1 dac, I needed to buy a tiny torx bit and it turned out the fuse was blown. I get to hear the Bryston balanced...it too is a true balanced design...I saw the four symmetrical and tiny SMD full discrete output stages of all the phases and single ended was not summed.
Without an AB to confirm, I suspected a few things about the Phoenix when using my memory of the Lehmann amp.
Perceived Negatives (More to these negatives a later)
1. The treble was a bit dark.
2. The amp is not as quick as the Lehmann
3. The bass was not as impactful or as tight as the Lehmann
Perceived Postives
1. Despite being darker it had more detail than the Lehmann
2. Staging and seperation and imaging was better than the Lehmann
3. Midrange was more realistic
4. Overall more organic
I liked how the Phoenix surprised me in that I never thought it would supersede my tube amp. Everything that I love about tubes, midrange smoothness, soundstaging, imaging and separation was better on the Phoenix. Better still the Phoenix didn't have that definitive softening of transients that my tube amps have when I AB with the Lehmann.
I have been complaining of a little brightness with my LCD2s when I paired the Reference 7 to the Lehmann amp. And lately for musical listening...I fell back on my Cayin tube amp in SET operation. I considered the possibility of a tubed NOS dac...as I have come to enjoy NOS dacs and tubes. With the Phoenix in the mix....I never felt the need for my tube setup or a NOS dac. I feel I am "there" with tonality.
Is this the result of pure class A? Perhaps its the no opamps, purely discreet output? Or maybe Kingwa is freakin psychic and new to voice it how I like it...or perhaps he voices things like how I tend to like things? Still...the Phoenix claims to be a "wire with gain" with utter neutrality...yet the Black cube lays the same claim, but they're polar opposites.
The common perception of "neutrality" and "wire with gain" seems to be one of leaness and analytical in signature...for which the Lehmann BCL would fit this description a little better than the Phoenix. I felt the Lehmann was more analytical because I heard dramatic differences between the Bryston and Ref 7 dacs...I guess the way the BCL was voiced doubled up on how the Bryston was voiced and the differences were staggering.
Moreover it seems like the Bryston ran more optimally balanced as the number one complaint of an uncontrolled and loose sub bass was not at all noticeable balanced into the Phoenix. Moreover my complaint the Bryston was too lean in the mids and not realistic enough was nullified by the Phoenixes mid range portrayal. I would have been 100 percent satisfied with the Bryston and Phoenix combo. Fortunately the Ref 7 retained an advantage over the Bryston...however that advantage it enjoyed which was so vast with the Lehmann amp was no where near as dramatic as the Phoenix tended to bring the two dacs closer to performance.
Which lead me to suspect that the Lehmann amp must therefore be more resolving than the Phoenix, and so I listed all the negatives as above. Without a direct comparison...I felt the Lehmann was ahead in key technical benchmarks such as speed, dynamics and clarity.
However when it came time to carry out the actual AB comparisons I was relieved. Switching from the Phoenix to the Lehmann showed the Lehmanns limitations...it could not resolve the soundstage, detailing and seperation of the midrange as effectively as the Phoenix. The Phoenix was on par with the speed of the Lehmann, bass was just as dynamic tight and impactful and treble was just as extended and present with equal amplitudes. In other words bass and treble amplitudes were the same, transients were the same. Impact and dynamic were actually much better on the Phoenix due to the blacker background and more power.
So the ONLY difference that was notable enough to skew my perceptions was the one of midrange resolution. The increased data, information or "bandwidth" in the midrange, as a result of more detail, soundstage, imaging and separation data draws your poor bandwidth limited attention span away from the treble and bass and into the mids. The sensation that it was slower was due entirely to the lesser treble to midrange data ratio. That is the brighter Lehmann seemed quicker...merely by being brighter and not at all faster.
Having said that, I guess the Lehmann is a lot more capable than most members give it credit for. However when directly compared to the Phoenix, the information relay to my ears is of a much lower bandwidth than the Phoenix. The Phoenix relays more data and information to my transducers and I can perceive this extra information easily and most of this information - 90 percent or so of the extra data is coming from the midrange alone. The key difference is a more realistic stage, separation, layering and imaging...the sound being 3 dimensional and tonally orientated correctly towards the mids.
My headphone experience has never been more true to life. I don't see the relevance of tubes and NOS dacs...the Phoenix amp can give me all this with the DS Bryston DAC...and it gets better with the Reference 7 in the mix. It has dawned on me that "synergy" is more important than "topology".
