lmswjm
- May 1, 2008
X2
Originally Posted by SoupRKnowva /img/forum/go_quote.gif hey Peete, would you be willing to write down a list of quantities and sizes for all the new capacitors you bought to replace the ones in the Phoenix? just to use as a parts list for someone not quite a technically inclined as yourself? And i know you used larger sizes in the PSU section for more filtering, but are you going to keep the sizes the same in the amp section of the unit? Also i was curious about gauges and lengths of wire that you used in the rewire of the whole thing as well. or do you think that it would be ok to use all one gauge, like 24 or 26 awg? im fairly partial to the SCSCag wire that cryparts has which only comes in those 2 sizes, which is around 10 bucks a foot. Do you think i should just stick with the mundorf like you used? Im just curious because i think that ive finally decided that i want one of these beasts, and i like what you've done with your mods, so im going to contact Kingwa about me sending all the parts and just having it built with the new caps and wire in it already and since i dont have one i cant go look for myself. also need to discuss having a lower gain put in for my jh-13's thanks ahead of time, i dont think im the only one in the thread that appreciates what you've done. |
Originally Posted by lmswjm /img/forum/go_quote.gif X2 |
Originally Posted by Pricklely Peete /img/forum/go_quote.gif Curra and I were chatting about the mods (Phoenix and RE1),parts list last weekend so he suggested a spread sheet to list all of what I have done and plan to do in the coming weeks (sizes, values etc). Everything needed to bring the units up to the latest rev (Max mod I call it) if others wish to follow suit. I'll let you guys know when the Phoenix sheet is ready. Should be sometime this weekend. Peete. EDIT: It's done ! PM me with your email address if you want the Phoenix BOM pdf. |
Originally Posted by SoupRKnowva /img/forum/go_quote.gif haha i shoulda known you would be ahead of me on that one peete so how do you feel about the wire thing i was talking about? |
Originally Posted by Pricklely Peete /img/forum/go_quote.gif 24 awg is a good size for the back panel I/O but I would go with regular 5N solid silver 22 awg or bigger for the DC lines (internal and cables). 10 bucks a foot seems a little steep ...the Mundorf stuff is 4.20 a foot (24 awg) while the 5N 22 awg silver is around the same range (under 5 bucks a foot). The pdf BOM has everything listed but no instructions. Cap sizes in the amp section will not change for the smaller caps used (100uf Nover replaced with Nichicon 100uf 25V KZ MUSE ) but the 5 larger caps (4 in the head-amp section, 1 near the acss stages) are swapped out for 2200uf 25V and 1 2200uf 35V Nichicon FG (fine gold). It's easier to explain if you are familiar with the internal layout. Peete. |
Originally Posted by SoupRKnowva /img/forum/go_quote.gif oh got ya, i think then that ill just stick with the mundorf you used since it doesnt cost too much, and you say it sounds good. And ill probably buy and extra 25% of everything in case its bad or they screw something up while building it, and have them throw anything extra back in the box when they ship it too me. and again thanks for all the effort you put into this peete Edit: and you havent actually done the cap upgrades in the amp portion yet right? might wait to see how much awesomer it gets with those |
You might as well get the Phoenix if you have the HD800.
Do you really think the Phoenix would work well with the HD800? I would like to try the HD800 balanced, but I wonder if the Phoenix will work best with the HD800. (I already have balanced cables for the HD800.) In SE my HD800s work very well with the Corda Opera which is know as a warm amp. Unless I have misread, most reviewers feel the Phoenix is completely transparent, maybe even a tiny (very tiny) bit thin. I am guessing my T1s would work great with the Phoenix, but I am reluctant to reterminate my cable which is more difficult with the T1 than the HD800.
