Pharmaboy
Did some testing and so far I came to the following results: (all testing done using WASAPI exclusive mode)
Amanero 1.067 drivers fails (8K bytes packages bulk transmission)
Device locks up completely after any amount of time (sometimes after only 10 minutes, sometimes after 1.5 hours)
Testing with ASIO mode give the same results
Amanero 1.062 drivers from Audio-GD website works (8K bytes packages bulk transmission)
I played a shuffled playlist continuously for 14 hours without any lock ups or errors, at this point I think I can call that "working".
Amanero Microsoft Windows provided drivers works (3K bytes packages asynchronous transmission)
I played a shuffled playlist continuously for 12 hours without any lock ups or errors, at this point like the others drivers I can call this "working"
As said before Microsoft doesn't provide an ASIO driver for the Amanero interface so that's not available. Perhaps it would work if you keep the Microsoft drivers and install the ASIO driver package from Amanero separately.. have not tested this and I'm not going to, I don't care for ASIO.
Microsoft Windows provided drivers for the Realtek ALC1220 codec optical out into the optical in of the Audio-GD NFB-11.38 works
Didn't expect any troubles with this option and non showed up, device ran without lock ups or errors for hours.
Pro: electrically isolated from the rest of the system.
Con: limited bandwidth, max 24/96 (which is more than enough for for the 2 channel PCM what I use it for, all my FLAC files are 16/44.1)
Con: Not sure if it's just my unit but the connector of the optical cable sits super loose in the socket on the Audio-GD, it's takes like no force at all to unplug the connector from the socket.
No idea what the difference(s) is/are between the generic 1.067 and the Audio-GD 1.062 drivers but there must be something as my unit at least is not happy with the 1.067 drivers at all.
I'm thinking about what interface to keep using, USB or optical. Both have something going for them.
At the moment I'm leaning towards the Amanero USB interface with the 1.062 drivers. Audio-GD unit comes with an "expensive" Amanero interface module so might as well use it. Also I have more confidence in the Audio-GD unit taking care of the clocks then the Realtek codec when using optical.
Thanks for the information
My unit seems to be working fine with the Audio-GD 1.062 drivers and the drivers provided by Windows.
So at this point I'm not so comfortable flashing firmware as it is working now.. don't try to fix something that ain't broken
You obviously know more about USB input & drivers than I ever will--but I offer this observation regardless:
- When I got my first DAC (a then praised delta/sigma design from Korea), I found its sound off-putting: bright, edgy, harmonically thin, all the digital nasties people talk about. I read that synchronous USB inputs were partly to blame, so picked up a SPDIF converter (Musical Fidelity V-Link96) + pricey toslink cable to use instead of USB. That made a real sonic improvement, so I stayed with it.
- Then I switched to a better sounding d/s DAC, the humble Peachtree Audio DAC iTx (which I still sometimes use). The iTx could decode 24 bit/192 kHz files, so I upgraded the converter to Musical Fidelity's V-Link192. I compared USB vs optical w/the iTx and found there was still a very slight advantage to optical. But I could easily hear that the asynchronous USB input board of the iTx (described as "galvanically isolated") was a clear upgrade over my 1st DAC.
- ~5 years ago I got my first NOS DAC, the Audio GD NOS 19. Again optical sounded better than USB with this DAC. I decided to fool around with coax and started out w/an inexpensive 1.5M Billy Jeans coax cable. That sounded better than optical and way better than digital.
- Eventually I sprung for a more expensive silver coax cable some praised: Oyaide R-510 (1.3M). Well, damn! With this new coax cable and the NOS 19, I suddenly had by far the best digital I'd ever heard IMS. Much of the note dimensionality, natural musical flow, and weight in lower registers of excellent high-end audio was now present.
- 2 DACs later (Audio GD DAC-19; now MHDT Labs Orchid), I still find the sonics of the SPDIF converter + silver coax cable superior to USB.
I also found the whole firmware-update thing very intimidating w/Audio GD gear. I've read enough about this tricky process to know I'll never do it. BTW, I remain an Audio GD fanboy despite these issues--I like the "house sound" a lot (also have/had 2 AGD headphone amps).
One of the best things about coax is that it bypasses all the tricky which-DAC-driver-works-best issue you outline in your post. I just don't think about DAC drivers now.
