Hi Lads/Guys. I am not sure it is a right thread, but R2R-11 thread is in the amp section and this matter is about interfacing and Amanero module.
To cut it short, skip this paragraph. I have an old laptop with Core 2 Duo CPU, Windows 7 for playing music, as it gives the best SQ. It was already partially damaged, LCD screen with vertical strips (not repairable), so I use external VGA monitor. Recently during a power outage (which are common in democratic South Africa protecting common criminals and copper cable theft), power supply was blown. After replacing power brick I found damaged number of items, a laptop screen lost a backlit, USB hard drive and USB port on the hub R2R-11 had been attached not working anymore. Luckily a DAC survived, but I started to experience ID problems and cutting off playback. It was the same on the other computer with Windows 10, so I suspected the worse, but it happened the same external monitor giving a strong AC leak, monitor is also damaged, a DAC is not!!!
For the above reason I started to investigate USB interface and discovered that my Amanero module is not using isochronous but bulk USB transfers -- the same as storage devices (memory sticks and hard drives). See attached two screenshots of a performance monitor. This Windows built-in application is partially functioning (some counters not loaded or not working), so I downloaded a trial version of
USBlyzer that confirms this fact, see the last screenshot.
Amanero driver is initiating playback using #2 endpoint, which is a bulk transfer, not the endpoint #5 which is advertised in device properties for isochronous asynchronous transfers. It is the same when starting WASAPI event/push, ASIO and DS (system mixer) playback. There is also the same on Windows 10 PC. I updated to the latest driver v1.0.67, it changes transfer buffer size from 32kB to 8kB, no other changes. Firmware on the Amanero module is already updated .
My R2R-11 is an older version (pre-2019), it is interesting to compare other versions, also other Audio GD DACs. Maybe my Amanero module is damaged, so I need your feedback.
@ProLoL, is it answer to your question?
Using a tool is simple, but requires prior installation and OS restart:
1. Attach a DAC. Start and stop playback to wake-up hard drives.
2. Start USBlyzer.
3. In device tree window tick a box next to the Amaneno device (highlighting is not enough).
4. Click "Start capture" icon.
5. Start playback.
6. Wait few seconds and stop capturing.
