doyouknowSBmean
Is the master 10 a pure class A amp? Thanks.
Master 10 works in class AB while master 11 works in class A normally.
Thanks for the update on your USB impressions.
So the Combo384 runs off USB power? For some reason I thought it ran off internal power.
BTW, which Teradak are you using?
Nice stuff, thanks for the deets. Do keep us posted... enquiring M11 owners want to know.
Oh man, you're getting the MCU programmer too... I was thinking about it when I saw it posted in the M7 thread. May just have to jump and order one from audio-gd before my M11 ships. I'm not too sure what it can do, but doesn't hurt to be prepared in case some stellar results are discovered.
What's the obsession with class A? I"ve read few posts on other threads asking about the same thing...
I'm really not sure if buying the MCU programmer tool is worth it. I bought one off ebay for 10bucks. but just want to change the introduction messages to be the model numbers...
my NFB28 used to say nfb28 when it booted, now says AGD10
but minor.
i like having volume levels set specfic for each input. otherwise, not sure if kingwa will explain what new features or options will be available for mod.
Master 11 in the house! Although someone forgot to install the HDMI port. It came with RJ45. Well it's easy to swap as far as I know.
