Audio-gd Digital Interface
May 14, 2013 at 3:28 AM Post #3,826 of 4,156
We have got few users feeback update the firmware fail, so we are afraid make the trouble to users.
We have bough the SBT from HongKong since 20th April but the saller still have not shipping to us.
Any users can update the firmware. But consider the fail risk and read the guide careful.
USB32 V2.0 driver
1, ASIO can select support up to 32bit (for DAC ) and up to 24bit (for DI-V3)
2, Support 32bit 384KHz (Some DA model may can't support 384K playback)
3, Firmware update (Must update the firmware for work with V2.0 driver)  for mac , Windows ,Linux (test ) (A lot users had update succeed, but few users have fail and want to buy the new Firmware , price is USD1 exclude shipping cost.)
  Download the USB32 V2.0 driver:   http://www.audio-gd.com/AudiogdUSB32v2.0forwin.rar
  Download the USB32 V2.0 driver install guide :  http://www.audio-gd.com/Driver%20install%20guide.rar
  Download the firmware update tool :  http://www.audio-gd.com/USB32firmware.rar
May 14, 2013 at 3:56 AM Post #3,827 of 4,156
I must be very lucky guys...never had problems in the past. I've downloaded and installed the new drivers, updated the firmware and the sound is just fine!! But I'm using a usb32 dac: at this point I think the problem is with the DI, despite using the same chipset.
Just to chime in. I've updated to the DI, and have no problems at all. Other than a silly mistake which I did earlier. At this point tin time, I can only say the update brought some improvements in the soundstage (wider, deeper), balanced in timbre, better layering and separation of instruments and bass seems to have more texture. One thing I like using via ASIO is how analogue sounding is the whole set-up now.
May 14, 2013 at 4:12 AM Post #3,828 of 4,156
AudioGD seems to have taken down the announcement from their home page. I think you can still get FW#7 from http://www.audio-gd.com/Pro/Headphoneamp/Compass%202/Compass384EN.htm ( download the v2.0 package for USB32 ). I've tried FW #7 with SBT / EDO, but it's a no go. You get sound, but it's full of "cracklings".
Firmware #7 should be Asynchronous only then.
I wish someone could update the EDO custom kernel with the ALSA patch that's been release weeks ago... It probably would fix the issues with the VIA chip and finally allow async to work...
May 14, 2013 at 4:20 AM Post #3,829 of 4,156
Good! I'm glad someone else has done it :)
And i completely agree with you about the sound improvement. From what I heard yesterday it was about better dynamics and bass control...cello pizzicatos never sounded this gorgeous
May 21, 2013 at 9:18 AM Post #3,830 of 4,156
I will try my luck this night...
It would be nice if Audio-gd tell us the change log of this firmwares/drivers upgrades...
May 27, 2013 at 3:34 PM Post #3,836 of 4,156
@ Thegrobe
Its usually not that bad idea, to check product description page. Anyhow straight from the horse's mouth
http://www.audio-gd.com/Pro/dac/DIv3/DIv3EN.htm
"[size=x-small]6,Advice the  users who own audio-gd DACs had built in USB-32 don't want upgrade to the DI-V3 .[/size]"
Ah, yes. I looked over the product page but must have missed that. Thanks for the heads-up. I wonder then the DAC's that have the USB-32 built in, if there is any reason to mod the power supply (as in the DI-PSU) or if it's all self contained in the unit.
May 27, 2013 at 3:57 PM Post #3,837 of 4,156
There is no reason at all, USB-32 board draw power from inside the DAC, so its nice and dandy, or clean as you prefer. The only soft mod, which ppl reported as impacting sonic in good way was, was isolatation  of power pin in usb cable (isolation tape). Thread NFB-1.32 if i'm not mistaken.
May 27, 2013 at 5:30 PM Post #3,838 of 4,156
Apart from driver changes, what can be expected from firmware 7 VS previous firmware versions?
Regards
USB32 V2.0 driver
Kingwa (or whoever who may know).
May 27, 2013 at 5:38 PM Post #3,839 of 4,156
Is there any advantage to using the DI-V3 if your Audio-GD DAC already has the USB-32 module? (current SA-1.32, SA-2, etc)
With or without additional power supply, etc?
Thanks!
The main advantage of running the built-in USB-32 in your DAC is that it's connected in I2S instead of coax. Only few DAC can support external I2S signals through RJ45 pors (Master 7 is one of them, the others I didn't check).
May 27, 2013 at 9:17 PM Post #3,840 of 4,156
Regards
I noticed a fairly welcome change in the soundstage, specifically that it widened and the location of instruments in that soundstage have more depth and separation compared to before. Certain songs like the opening theme from metal gear solid 2 actually sound correct and no longer overcompressed (not sure how that works, but it's the first time I've heard it played back and everything just sounded "right"). The quality of the bass (the texture of it) is also better as well as a less sharp treble, if that's what i'm hearing correctly. Sibilance seems a little less as well.
In a nutshell I'd use the word layering to describe what this firmware did for me at least. Lots of delicious layers.
